Dectane/Depo LED rears on 997.1 - mounting screw?
Old Mar 29, 2012 | 05:16 AM
cl997's Avatar
cl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to behold
So i got these Dectane/DEPO LED rears for my 997.1. wired them up and they work fine. However the mounting screw(s) is completely different. On the 997.1 OEM lights there are two screws. On the DEPO/DECTANE LED's there is only one, and it's too far away from the body work to be secured properly (even with a really big washer).
Does anyone with a 997.1 who has installed these have any suggestions?
Old Mar 29, 2012 | 05:55 AM
m3drei's Avatar
m3drei is infamous around these parts
you will need to re-use your mounting bracket on your OEM lights.
Simply unbolt the big Philip screw from your OEM lights, remove the bracket, and re-bolt them onto the Repo lights.
Old Mar 29, 2012 | 06:08 AM
jhbrennan's Avatar
Here you go:
http://carlightpro.com/2011/04/installation/
Old Mar 29, 2012 | 06:27 AM
cl997's Avatar
Thank You VERY much. It would've been nice to have recieved some instructions with the lights. Rep points to you guys!
Old Mar 29, 2012 | 07:41 AM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
When removing your OEM lights, just unscrew the middle screw. The dectanes slide right into the OEM bracket. You place them and them screw the middle screw back in place.
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
orbelo
Aug 30, 2015 12:26 PM
