Need Help Figuring Out Wheel Offset
Old May 6, 2012 | 01:41 PM
PTParks's Avatar
PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !
My stock wheels have the wheel width and what I assume is the offset cast into the wheel where the valve stem is located. The numbers are 55 front and 67 rear. If this is the offset of the F/R wheels, does a lower number move the wheel out or in when compared to the stock offset? Thanks!!
Old May 6, 2012 | 04:17 PM
MYC2SPC's Avatar
MYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really nice
To measure backspace you would put a straight edge on the rear (inside of tire) wheel and measure the distance from the straight edge on wheel in to flange (which meets with rotor) which supports lug bolts.This gives you your b/s distance.
Old May 6, 2012 | 07:11 PM
Boosted Josh's Avatar
Boosted Josh is infamous around these parts
Yes the numbers in the wheels are the offsets. The fronts are +55mm and the rear are +67mm.
Lower number means pushed further out. As long as the wheel width is the same.
Look up offset calculator on the net to determine how it will change based on offset and also wheel width.
Old May 7, 2012 | 07:06 AM
jhbrennan's Avatar
This will help:
http://1010tires.com/WheelOffsetCalculator.asp
Old May 7, 2012 | 04:05 PM
PTParks's Avatar
Originally Posted by jhbrennan
Ah, Offset For Dummies!! Thanks!!
Mar48
Aug 24, 2015 01:13 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
