Water Pump Leak?? question!!
Old Aug 23, 2012 | 08:30 AM
LMM's Avatar
LMM
LMM is infamous around these parts
Getting mine replaced now. It is a '07 with 35k miles on it. Dealer charging me $1.1k!
Old Aug 23, 2012 | 08:36 AM
MBENZF1's Avatar
MBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud of
1.1K? Ouch, you got bent over pretty good.
Old Aug 23, 2012 | 08:54 AM
LMM's Avatar
LMM
Yeah, and it doesn't feel good. Funny/sad thing is that I called another dealer and they wanted around $1.4k. Guess it is the Fairfield County, CT markup!
Old Aug 23, 2012 | 03:07 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Originally Posted by simtiaz
Car is at local indy shop and I was notified that I need to change my water pump becuase there is a leak. Car is 06 C2s with 38k miles and tech showed me what looks to be dried light pink residue. There is no moist, or drip at the the moment and my coolant is slighlty below minimum mark.
do the water pump go bad this early? do I really need to change the water pump or could be the bolt that needs to be tightened up?
I wanted to hear form you guys what do you think?
Pretty common issue and the part costs $ 240 at Suncoast. Don't think I'd chance not replacing it considering the potential cost of a full blown water pump failure. What's your indy quoting you to do the work ?
Old Aug 23, 2012 | 03:10 PM
IslandS62's Avatar
IslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of light
There is a guy on Rennlist selling new Porsche 996/997 water pumps for $125. I picked one up just to store for when the time comes to replace. They are $350 or so on Pelican.
Old Aug 23, 2012 | 03:30 PM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
Make sure you have the pump checked for damage. The plastic propellers have been known to break apart and the pieces clog the oil galleys.
Old Aug 23, 2012 | 03:49 PM
dbcperformance's Avatar
dbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant future
It is a common parts failure we see almost every other week at our shop (yes you read it right, that often). 20k-50k is where they fall at. No need to panic about it, it is a pretty easy fix.
If anyone interested in, I have Lasso pumps for $199.00 and Genuine ones for $260.00.
We charge around $670.00 for a replacement including coolant flush.
Old Aug 24, 2012 | 09:26 AM
Jack667's Avatar
Jack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant future
Mine failed this morning. Heard a squeaking noise, went to dealership. $1075. Three months out of warranty.
Old Aug 24, 2012 | 09:39 AM
daberlin's Avatar
daberlin is a splendid one to beholddaberlin is a splendid one to beholddaberlin is a splendid one to beholddaberlin is a splendid one to beholddaberlin is a splendid one to beholddaberlin is a splendid one to beholddaberlin is a splendid one to behold
Is there a general consensus on water pump preventive maintenence for 997's? My old E39 and E46 BMWs each started life (as well as my current Audi Q5) with plastic impellers. BMW recommended 50k miles replacement on the pump. Are Porsches similar? Or do we just wait for the small drips on the garage floor? I never waited that long on my Bimmers. Early swaps for upgraded pumps. Audi pump failed at 1 year (recall item). Just thinking ahead for my 997.2.
Thanks, David
Old Aug 24, 2012 | 03:04 PM
Tito_gsx's Avatar
Tito_gsx is infamous around these parts
Yah I'm in the same boat. I have 06 with 42k miles, my mechanic says not to worry about it (was dry when he last worked on car 6 months ago). By reading these posts I get feeling that WP replacement is imminent
Old Aug 24, 2012 | 03:19 PM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
I'm sure you didn't mean oil galleys.
Old Aug 24, 2012 | 10:45 PM
Sharkys's Avatar
Sharkys is infamous around these parts
Normal. I replaced my pump due to dry seepage residue. Only $850 including part. Also replaced serpentine belt while the pump was being replaced.
Old Aug 26, 2012 | 08:06 AM
GordieHM's Avatar
GordieHM is infamous around these parts
Mine went at 80,000 miles. it just went and shot coolant all over the place on the road. Changed it myself. Was a little harder to do then I first thought.
Old Sep 17, 2012 | 11:03 PM
Michaelwww's Avatar
Michaelwww is a jewel in the roughMichaelwww is a jewel in the roughMichaelwww is a jewel in the rough
Originally Posted by keny
I just replaced mine at 40 000 km recently. Noticed a pinkish patch of water on the floor under the pump.
Before that it started to have a squeaky bearing noise coming from it.
Cost me about 800 to replace it.
Did it sound like this...
Old Sep 18, 2012 | 02:17 AM
memo555's Avatar
memo555 is infamous around these parts
Originally Posted by Michaelwww
that definitely sounds like the water pump to me..
turbotuner20v
Sep 11, 2015 12:02 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
