will this multifunction wheel fit directly?
Old Oct 6, 2012 | 04:49 PM
Phantome46's Avatar
Phantome46 has much to be proud ofPhantome46 has much to be proud ofPhantome46 has much to be proud ofPhantome46 has much to be proud ofPhantome46 has much to be proud ofPhantome46 has much to be proud ofPhantome46 has much to be proud ofPhantome46 has much to be proud of
Does anyone have pictures of the correct control unit or a schematic that I can follow?
Old Dec 3, 2012 | 08:11 AM
Phantome46's Avatar
Do you guys have any experience with the coding side of the steering wheel activation?
Just connected a durametric pro to the car and was able to open the
Gateway option and bring up the coding option - from which went does to the multifunction steering wheel drop down and clicked active (was originally inactive)
Tried to open the steering column area and could not get the coding box
Then tried the PCM gateway and could not get that to connect to the durametric at all?
Am using durametric 6 but had issues with communicating to the car?
Could you guys provide any help?
Old Dec 23, 2014 | 10:12 PM
BSU's Avatar
BSU
BSU is infamous around these parts
I am having trouble with this as well.
I just installed a multifunction steering wheel in my 09 997.2 and today my dealer could not get it activated. They could not find the multifunction "switch" in the system to turn it on.
Does anyone know if there is a particular procedure for turning on the multifunction controls, or does it just not work with some 997.2s?
Old Dec 25, 2014 | 01:54 PM
alirob's Avatar
alirob is infamous around these partsalirob is infamous around these parts
BSU: See my post of 09-18-2012.
Old Dec 26, 2014 | 05:22 AM
jhbrennan's Avatar
Were you ever able to get this done? In your 9/18/12 post it seemed like you were convinced by PCNA and others that it couldn't be done but then Suncoast and others responded that it could be done.
Old Dec 26, 2014 | 07:27 AM
alirob's Avatar
No, after months of trying I finally gave up.
Old Dec 29, 2014 | 08:02 AM
BSU's Avatar
BSU
Seems that the activation is usually very easy . . . but not 100%. Sounds like there may be a problem with very early build 997.2's.
Has anyone else had problems activating a multifunction steering wheel on a 997.2?
Old Dec 29, 2014 | 10:45 AM
Spudster's Avatar
Spudster Is a GOD !Spudster Is a GOD !Spudster Is a GOD !Spudster Is a GOD !Spudster Is a GOD !Spudster Is a GOD !Spudster Is a GOD !Spudster Is a GOD !Spudster Is a GOD !Spudster Is a GOD !Spudster Is a GOD !
My situation is slightly different but maybe this will help...I have a 997.1 tip and installed a 997.2 PDK wheel with multifunction. I have a PIWIS computer and what worked for me was to do a "Vehicle Handover" function. Basically what that does is restart all the computers in the car and syncs them all together. It worked on my car and a friends car that also installed a new steering wheel. Have the dealer try that and see if it works.
Old Dec 29, 2014 | 09:22 PM
BSU's Avatar
BSU
Thanks, we'll try that.
Old Dec 30, 2014 | 08:35 AM
jhbrennan's Avatar
Originally Posted by xgjjdj
My Porsche service dept. told me that it was not possible to upgrade to a multifunction on my 09 C2S PDK.
Go away.
Aug 21, 2015 09:56 AM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Vendor Classifieds
Aug 18, 2015 03:55 PM
