Oil Pressure Gage Question
Old Oct 29, 2012 | 01:21 PM
forbes210's Avatar
forbes210 is infamous around these parts
My readings are very random but discovered that most likely is caused by faulty oil pressure sending unit (located on a right side in engine bay are). Very often it shows high readings while the car is warmed up. If I'll knock on it with screwdriver reading seams to come back to normal which in my case is about 1.5 while idleing.
Old Oct 30, 2012 | 07:40 AM
Hatzenbach's Avatar
Hatzenbach has a spectacular aura aboutHatzenbach has a spectacular aura about
I also had random readings (needle constantly jumping up and down). In my case it turned out that the wire inside the crimp connector at the oil sensing unit had come loose. It was a very easy fix, basically finding the wire in the engine bay attaching a new connector and re-attaching the connector to the oil sensing unit.
By the way: If I recall it right, when there's no connection then the oil gauge will read 5, not 0
Old Oct 30, 2012 | 08:52 AM
luigi007's Avatar
luigi007 is infamous around these parts
Thanks for all the feedback. Need to check the wires to the oil sensing unit. It sounds like I have the same problem. Is there a video / instructions on how to do this?
Jul 29, 2019 11:13 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
