RPM per gear
Old Nov 8, 2012 | 09:53 AM
DoninDEN's Avatar
DoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond repute
Originally Posted by last911
They are simply parroting things they've heard from others and really don't know or understand what they're talking about.
Wow, harsh!
Yes, there is a lot of parroting of information that goes on; that is how information is shared. By lugging, I am referring to driving when, using another "parroted" term the engine is bogging down. I couldn't answer his question because I can't say specific RPMs in every gear, because its like pornography, it's awfully hard to describe, but you know it when you see it. You say its good for the car, I disagree.
The vehicle, the fuel and the passengers are load on the engine (and for retired engineers the golf clubs). Or in your retired mechanical engineer's mind is it only lugging if you have: (a) a trailer hitched up behind (b) a truck that (c) runs on diesel? Do you know what your talking about when you imply that the stress on an engine coming from a complete stop is not the same relative to the load on the engine?
I hope my response is as polite to you as your response was to me.
Old Nov 8, 2012 | 10:15 AM
last911's Avatar
last911 has a spectacular aura aboutlast911 has a spectacular aura about
"Lugging the engine" is trying to pull a large load from few revs from which the engine labors hard to overcome. Lugging is when the engine struggles to pick up the load. It usually occurs due to a lack of available torque.
There, I've tried to reduce lugging to its essence.
I never said lugging is good for an engine.
Cruising around town below 3000 rpm is not lugging.
Do you happen know what engine speeds Porsche's engineers have the PDK equipped GTS to run when driving under a light load (just cruising around town)? It's about 1500 rpm.
If you want to offer free technical information, try to be accurate or quote accurate sources.
Old Nov 8, 2012 | 10:24 AM
DoninDEN's Avatar
To follow your request, please list all your sources on any and all advice you provide so it can be clear you are not "parroting" information that someone else told you on a subject that you "really have no idea what you are talking about". Your demeanor is very huffy. LOL
Old Nov 8, 2012 | 10:41 AM
alpine-al's Avatar
alpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of light
Somewhat relevant to the topic, in my 997.1 C2 with Tiptronic on the highway moving 45 - 85 mph and with light pressure on the accelerator, the transmission down shifts at 1500 RPMs and upshifts at 2200 RPMs.
Old Nov 8, 2012 | 11:15 AM
last911's Avatar
36 years hands on experience at the Big Yellow Tractor Co. I worked in Engineering Design, Researh & Development, Marketing, Sales and Product Support. I had some very interesting postings in engine and machine development, running engines both on the dyno and in machines at the proving grounds and jobsites around the world. Other than a degree in Mechanical Engineering, and my applied experience, I don't know much on this subject.
Look, this is not a mine is bigger than yours contest. It just grates me when I read things posted by folks as technically accurate information or advice when the are off the mark. I'm sure that your as passionate about your life's work as I am about mine.
Old Nov 8, 2012 | 11:52 AM
DoninDEN's Avatar
It's a forum for Jimmy Cricket's sake! People trying to offer other people advice and help with their questions. Try to be nicer to other posters its a reflection on yourself.
Old Nov 8, 2012 | 02:23 PM
crazycarlitos's Avatar
crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !
Fred R... Why don't u just share ur extensive knowledge without being an a$s ?
Old Nov 8, 2012 | 06:41 PM
TT2911's Avatar
TT2911 is just really niceTT2911 is just really niceTT2911 is just really niceTT2911 is just really niceTT2911 is just really nice
Originally Posted by gibbonsc4s
Why never below 3000?
OK, I don't have a PHD in engineering but I've been racing and building engines for 30 years so take my "parroting" with a grain of salt:
"Lugging the engine" can also be defined as operating the engine under load outside of its ideal torque band for an extended period of time. In older engines that had carbs without computer controlled ignition, this could be harmful over time as it carboned up the engine, usually caused some amount of knocking/detonation and usually caused the motor to run hotter than ideal. Again, you would have to do this consistently for extended periods of time to cause any real damage.
In modern Porsche engines that are computer controlled and injected it's really hard to damage the engine by lugging unless you severely abuse it. The knock detector will automatically retard the timing, reduce the fuel, etc. That said, if you were to try climbing really long grades in the mtns and really lug the engine for an extended time, it could still get too warm.
IMHO the best way to drive your P car to enjoy it and get maximum life out of the engine is to rev it no higher than 3000 until it reaches full operating temp. Once it's warmed up, dont worry too much about shifting at precise rpm values. Dont drive like a granny all of the time below 3000 rpm because the IMS bearings get more oil at or above 3000 rpm so make sure you get to and stay above 3000 a little bit each time you drive the car. Other than that, just drive it in a spirited manner and relax and enjoy the car. Unless you are consistently banging the rev limiter you arent going to hurt the engine because they are built to be driven. The worst thing you can do to these cars is treat them like fine furniture and only polish them and look at them.
Old Nov 8, 2012 | 07:37 PM
exponential's Avatar
exponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to beholdexponential is a splendid one to behold
As a retired mechanical engineer, I have to laugh when folk on Porsche forums talk about lugging an engine when they have no idea what they're talking about. They are simply parroting things they've heard from others and really don't know or understand what they're talking about.
"Lugging the engine" is trying to pull a large load from few revs from which the engine labors hard to overcome. Pulling gently away from a stop at 700 revs is not lugging. Slow to 15 mph in 3rd or 4th, and try to accelerate hard at full throttle, approaches lugging. Try accelerating up a steep 10% grade in the mountains from 40mph in 6th, that's lugging. Try the same pulling a trailer and now you're really lugging. Lugging is when the engine struggles to pick up the load. It usually occurs due to a lack of available torque.
30 to 40 years ago when Porsches were powered by 2.0 to 2.7 liter engines with carbs, breaker point ignitions, running at speeds below 2500 to 3000 rpm could lug the engine. This was due to the fact that those engines couldn't produce enough torque to pickup and carry the load suddenly put upon it. Today with computer controlled fuel injection, ignition timing, variable cam timing and lift, Porsche engines produce so much torque at low speeds that it is VERY difficult to get in a lug condition.
Now if you want to drive around at 3000 rpm or above at all times because it makes the engine respond faster, fine. But don't delude yourself you're doing it to prolong engine life by avoiding lugging. You're actually wearing the rings and liners faster and burning more fuel.
You guys need to spend a few thousand miles in a diesel rig to really appreciate lugging.
Where is the L I K E button. I want to hit this button 1,000 times for last911. This is exactly what the fact is, not to parrot
Old Nov 9, 2012 | 09:19 AM
DoninDEN's Avatar
Exclamation
The little medal on the top right of the post is essentially the LIKE button. It allows you to give a rep to someone (like a kudos) who has posted something you liked or has been helpful to you.
Disclaimer, I am not a forum page developer nor have I been involved with the development of this page or the logic attributed to any of the features on this page. This response is hearsay and complete speculation and is not attributed to or approved by anyone associated with page.
Old Nov 9, 2012 | 09:01 PM
sixgun95's Avatar
sixgun95 is infamous around these parts
Well said!
Old Nov 10, 2012 | 01:23 PM
gibbonsc4s's Avatar
gibbonsc4s has a spectacular aura aboutgibbonsc4s has a spectacular aura about
This is actually a very helpful response. We shouldn't focus so much on the tone, there's really no sense in having such thin skin...
Old Nov 10, 2012 | 01:47 PM
Steve997S's Avatar
Steve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond repute
Gears are torque multipliers. While your input is generally correct and I agree, you can't completely and accurately speak about torque without adding gearing into the mix (Force), and the amount of force applied to the ground varies by gear and rpm. Therefore each gear varies in where lugging could occur. Generally, the force created in 1st and 2nd gears is so immense that lugging is impossible at any rpm within the range of the motor. Lugging is mostly at risk in the highest gears at rpms below 1,500 (assuming level travel).
On a side note generally speaking, one reason to avoid lugging the motor is to avoid piston slap. Piston slap can also occur when applying liberal throttle to a cold engine.
Old Nov 10, 2012 | 03:43 PM
DoninDEN's Avatar
[quote=gibbonsc4s;3688090]
]This is actually a very helpful response. We shouldn't focus so much on the tone, there's really no sense in having such thin skin...
Actually Fred provided a very poor response. I say so for two reasons. The first, I've said is because of the, I don't know how to act in public, tone. Like if I replied to your post by saying something like:
"If you had a intellectual capacity greater than a bowl of overcooked, day old, oatmeal you would clearly understand his response was as inadequate as Richard Chamberlain's inadequacy in fulfilling his marital obligations to Linda Evans."
But I have no reason to be a Buffoon. And you don't deserve that type of response.
The more important reason his response was lacking is he did not attempt to provide useful information by answering the OP's question. His response was a crotchety, half baked disagreement with another response. So it failed to be either informative to the OP, nor constructive. That is a double fail.
As he appears to have a great deal of information based on his professional experience, he should read the OP and give his advice. That would possibly be helpful and useful.
Old Nov 10, 2012 | 04:47 PM
gordon9898's Avatar
gordon9898 is a jewel in the roughgordon9898 is a jewel in the roughgordon9898 is a jewel in the roughgordon9898 is a jewel in the rough
Good info
lots of good info on this subject/thread, thanks!
