High speed air whisle
Old Nov 7, 2012 | 03:38 AM
Hyperseven's Avatar
Hyperseven is infamous around these parts
I recently bought a 997 C4S and i noticed that a speeds over 200km/h there is a whisle noice which is very annoying. I have tried tightening my mirrors but the problem is still there.
Does anybody have a clue what is the reason for this whisle?
Old Nov 7, 2012 | 08:02 AM
yvesvidal's Avatar
yvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of light
I wish we could have that problem in the USA.....
Yves
Old Nov 7, 2012 | 08:12 AM
ECS Tuning - Porsche's Avatar
Is it coming from one side more then the other ?
Old Nov 7, 2012 | 10:40 AM
Johnny DB's Avatar
Likely the horizontal seam on the mirror. Mine does that on the passenger side.
Old Nov 7, 2012 | 03:49 PM
Hyperseven's Avatar
I believe is from the left hand side of the windshield. Maybe there is something wrong with the rubber seal?
Old Nov 7, 2012 | 04:02 PM
GOB's Avatar
GOB
GOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud of
Years ago I had the same issue with my ex BMW M Coupe, except it happened only above 220 km/h. Only one mechanic dared to ride with me to find out the problem and as soon as he pushed out on the top right part of the windshield, the sound was gone.
Air pressure at that speed tends to slightly push the windshield "inwards" and sometimes there is a gap in the seal that causes the whistling sound. In my case, they had to re install the windshield and put a new outer rubber seal. Problem solved.
Old Nov 7, 2012 | 10:36 PM
drive2006c4s's Avatar
drive2006c4s is infamous around these parts
Hey it sounds like same problem I had. It came from passenger side mirror.
I couldn’t narrow it down until I brought it to the body shop.
About hour later he said the car is ready.
He told me that there is a gap between back side of the mirror and he put some kind of liquid sealer around the gap.
I borrowed someone’s side mirror pic to show you where the gap is. check my pic, see the yellow line that I drew. That’s the gap that it was making high pitch sound when I go over 50 mph.
Good Luck!
Old Nov 8, 2012 | 12:43 AM
dixoeileen's Avatar
dixoeileen is infamous around these parts
Old Nov 8, 2012 | 04:59 AM
Hyperseven's Avatar
Thanks for your advices. I think i will try using masking tape on various suspicious areas and try the car out until I hit the spot. As soon as i am 100% sure of what is causing the whisle i will visit the body shop to fix it.
Jun 10, 2017 07:45 PM
turkish1
Nov 11, 2015 09:01 PM
The Oss
Aug 24, 2015 08:19 PM
