Problems on the way home today....help
Old Nov 27, 2012 | 07:36 AM
ScooterP's Avatar
ScooterP is just really niceScooterP is just really niceScooterP is just really niceScooterP is just really nice
Originally Posted by tommyv
I had to think hard before I posted but it's exactly what happened with mine.
Tom
Don't worry about posting. All things must be considered and it is good to understand everyone's experience with these cars, regardless of the circumstances. No flame here.
Old Nov 27, 2012 | 07:48 AM
Darthvader's Avatar
Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !
The get service light came on this morning. They cant get me in until Thursday....should I rent a car?
Old Nov 27, 2012 | 08:18 AM
JB in AR's Avatar
JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !
If you need to get around and you have no other options, then I would say, yes.
Check your insurance policy or call your agent to see if they will cover any towing/recovery charges for vehicle breakdown. Mine does.
Old Nov 27, 2012 | 10:25 AM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
D not drive the car anywhere. Have it towed to the shop via flatbed. Rent a car or call a taxi. If something is wrong with the engine, every revolution could do more damage.
That being said, it sounds more like an ignition problem than anything.
Old Nov 27, 2012 | 09:05 PM
lenelsa's Avatar
lenelsa is infamous around these parts
Definitely not IMS issue from reading your experience.
Definitely have it flat bedded to dealer .
Old Nov 28, 2012 | 03:55 AM
Fahrer's Avatar
Fahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to all
I am thinking it is more likely the MAF, an oxygen sensor or an ignition coil.
Old Nov 28, 2012 | 07:44 AM
Darthvader's Avatar
After reading a lot of material this seems the most likely to me as well. Should know tomorrow.
Old Nov 28, 2012 | 07:55 AM
JB in AR's Avatar
When you drove it home after filling it up the other night, did the CEL go out as well when the bucking stopped?
Old Nov 28, 2012 | 08:15 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Whatever it is - since you don't know - have it towed to the dealership so it's there as soon as they have time to look at it. Any insurance/warranty/extended service you might have (and should) will not cover your problem if you don't stop immediately and have it towed in.
Old Nov 28, 2012 | 08:30 AM
Darthvader's Avatar
I did not look and have not been in it since. Driving the wife's for now.
Old Nov 28, 2012 | 08:57 AM
Darthvader's Avatar
One would think that these cars with a brain would be able to tell wether it's safe to drive the car. It's just a simple matter of a well written algorithm. No?
Old Nov 28, 2012 | 09:00 AM
krysFly's Avatar
krysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant future
I had very similar issues, it turned out to be 3 cracked ignition coils, plus I changed the plugs. No issues since.
Old Nov 28, 2012 | 09:03 AM
b2sc's Avatar
b2sc is infamous around these parts
Defintley sounds like the ignition is misfiring the way it's bucking. Is this happening at all revs or just above 3 or 4 k rpm?
Good luck.
Old Nov 28, 2012 | 09:30 AM
Darthvader's Avatar
Above 3 or 4 RPMs I believe. Happened while exiting the freeway so after I was home in a couple of minutes. Then I took it for gas thinking my wife put **** water gas in it. Don't recall it happening on the way home from the station. Have not driven it since. 20,600 miles,full inspection and oil service 3k miles ago.
Old Nov 29, 2012 | 08:26 AM
Darthvader's Avatar
At the shop now. Feels like my kid is being tested for something.
