Bosch battery cost?
Old Nov 29, 2012 | 05:01 PM
jhbrennan's Avatar
Originally Posted by Darthvader
I used to live in WI and many pals worked there so I know this. The dealer talked to me like they do young girls. He said if you use anything but a Bosch there won't be enough amperage and your alternator will go which cost 1200 to replace
Q
Don't know why your dealer is talking about Bosch - the OEM battery is Moll.
http://www.mollbatterien.com/
Old Nov 29, 2012 | 08:31 PM
911bob's Avatar
911bob is infamous around these parts911bob is infamous around these parts
I paid 300 for a new bosch battery installed
Old Nov 29, 2012 | 11:49 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Interesting. I needed a new battery last year and my dealer told me not to buy the factory battery as they have more problems than their other battery. The battery installed cost me $145.00.
Old Nov 29, 2012 | 11:53 PM
911bob's Avatar
Wow... No comment. I had just bought the car. Paid 500 for oil change and battery. Did I get ripped off??
Old Nov 30, 2012 | 04:34 AM
JB in AR's Avatar
JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !
If done by a Porsche dealer.
Ripped off? No.
Paid a bit much? Yes.
You will always pay more at a dealer, but you are also paying for a higher overhead to maintain trained staff, proper tools and tech pubs, information about your car, and a dealer stamp. For simple oil changes and battery swaps, you can do it yourself or use an indy. For DV's problem, he was safer going to a Porsche certified shop., as there was a big question about what the problem was.In my worthless opinion, any decent shop will test the charging system before and after replacing a battery to ensure any problems are noted and then resolved after replacement. This takes a bit more labor, but it's peace of mind.
Just my POV.
Old Nov 30, 2012 | 06:15 AM
GregGH's Avatar
GregGH is infamous around these parts
Originally Posted by alpine-al
Most car batteries are manufactured by Johnson Controls Inc, including the batteries sold at Walmart, Sears, Autozone, and Advance Auto Parts. They also make Interstate batteries as well as many original equipment batteries. And, they own Optima batteries too.
Other large makers are Exide and East Penn (Deka) ... all do lots of private branding ( which makes Consumer Reports tests on battery so annoying. The 'cheap' batteries are offshore - more often Korean ( AC Delco has an 'econo' line ).
Drop by most Interstate stores and they can a free battery test (testers should look similar to this design)... based upon the original CCA ( cold cranking amps ) they can give you a print out of the remaining life ..typically anything over 4 years is 'ready to let you down' ...and in HOT or COLD weather is when the battery & system is taxed the most.
Not exactly a car battery data sheet - try this - a real handy battery info sheet.
Greg
Old Dec 9, 2012 | 04:18 PM
tiyyara's Avatar
tiyyara is infamous around these parts
I paid 185 for the original battery. I bought it from the dealer on my way home from work, (called them in the morning and they put the acid in and charged it during the day). And then installed it myself, 15 minutes and had to get into the "trunk". My son thought it was
Old Dec 9, 2012 | 07:05 PM
MarathonBob's Avatar
MarathonBob has a spectacular aura aboutMarathonBob has a spectacular aura aboutMarathonBob has a spectacular aura about
Walmart has worked fine
I replaced my original battery in an '06 C4 over a year ago with a ~ $125 Walmart battery after reading many, many posts here. It was easy to install and has worked perfectly. It's got a long warranty - 4 years I think and there's a million Walmarts if I need a replacement. I'm no fan of Walmart but it's an invisible component; buried underneath a plastic shroud, covered by a Frunk, and is made by a 3rd party that makes most other American batteries. And it works great! Save your money!
Old Dec 9, 2012 | 07:25 PM
911bob's Avatar
As I read and read ... I feel ripped off!!!!!
Old Dec 9, 2012 | 07:32 PM
Darthvader's Avatar
Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !Darthvader Is a GOD !
Live and learn as it were!
Old Dec 10, 2012 | 03:35 AM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
Just replaced mine with everstart max h7. Excellent choice. Great performance. So far..
tropicatango
Jun 8, 2025 01:00 PM
adnanm3
Nov 22, 2023 02:43 AM
cm09578
Sep 22, 2015 06:07 AM
Serg124
Sep 10, 2015 05:27 AM
NTIMD8
Sep 1, 2015 09:58 AM
