Rear Interior Side Panel Removal 997.2
Old Feb 20, 2013 | 10:38 PM
Ghost Rider1's Avatar
Ghost Rider1 is infamous around these parts
Long time stalker, first time poster. I'm wanting to remove the rear interior panel on my 997.2, but I've come up empty on my searches. I did find a post on how to remove this panel on the 997.1, but I quickly understood the two processes are more different than one might anticipate. Any help for the 997.2 rear interior panel removal would be greatly appreciated. Thanks!!
Old Feb 23, 2013 | 11:04 AM
Bump.
Old Feb 23, 2013 | 11:26 AM
Ale_72's Avatar
Ale_72 has much to be proud ofAle_72 has much to be proud ofAle_72 has much to be proud ofAle_72 has much to be proud ofAle_72 has much to be proud ofAle_72 has much to be proud ofAle_72 has much to be proud ofAle_72 has much to be proud ofAle_72 has much to be proud of
Meanwhile you get some answer if you could post the link to the instructions for the MKI, I'd appreciate it. Thanks!
Old Feb 23, 2013 | 07:36 PM
dallascajun's Avatar
dallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant future
I'm interested in a DIY as well. Would like to install some sound deadening back there to manage the tire noise. In speaking with the tech at the dealer, this is one area that has little to no insulation.
Old Feb 25, 2013 | 12:31 AM
Here's the info I read elsewhere. I hope it helps.
1. Pull seat belt rose cover up and off.
2. Undo fastening screw behind it (be careful not to drop it into the chassis).
3. Detach side-panel lining by unscrewing the hex bolt for the rear seat latch. Pull locking lugs of side-panel lining out of the clips in the rear side section and move forward enough to get at the back of the speaker.
4. Disconnect the loudspeaker electrical plug connection and disconnect. Remove panel.
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
alevine
Nov 4, 2015 10:05 AM
gulf gt
Aug 27, 2015 10:27 AM
Jeff1smith
Aug 19, 2015 09:41 PM
