Squeaking Brakes
Old Mar 8, 2013 | 08:12 PM
3POINT8's Avatar
3POINT8 is infamous around these parts
Squeaking Brakes
I have a 06 911S with 45500 miles. Every time I put decent pressure on the brakes they squeak. This started yesterday. Any chance this is caused by dust or is it time to replace the brakes?
Old Mar 8, 2013 | 09:58 PM
devil boy's Avatar
devil boy is infamous around these parts
If the pads are getting thin then it's probably time to change them. If they still got some meat to them, then they're probably just dusty and need cleaned.
Old Mar 9, 2013 | 05:50 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
I doubt it s dust on these types of wheels....dust squealing was big on rear drums which we obviously don t have...... check your brakes.
Old Mar 9, 2013 | 10:58 AM
jacques1960's Avatar
jacques1960 is just really nicejacques1960 is just really nicejacques1960 is just really nicejacques1960 is just really nice
If brakes are in good condition, ask your mechanic to shim the pads; brake noise mau occassionally be caused by pad vibration
Old Mar 9, 2013 | 11:14 AM
3POINT8's Avatar
Crap. How much is this going to cost?
Old Mar 9, 2013 | 07:44 PM
monojohn's Avatar
monojohn is just really nicemonojohn is just really nicemonojohn is just really nicemonojohn is just really nice
Couple things could be going on:
1) Your pads could be glazed. Lot's of city or stop and go driving will do that. Try hard braking to burn the glaze off. Get up to 40mph or more and jam on the brakes very hard. Then do it a couple more times. Obviously, be careful that nobody else is around.
2) At 45,000 miles you might be due for new rotors. If a lip/bead has formed on the disc they will squeal more.
3) It's possible, but not likely, that the anti squeal shims are no longer stuck to the pads. That's an easy fix. Just a can of anti squeal spray applied to the back of each pad.
It's likely not dust.
The worst case here is that you need new discs. That's a few hundred bucks. A pair of OEM discs is about $350 for parts. Not terrible.
Good luck.
Old Mar 9, 2013 | 09:30 PM
3POINT8's Avatar
Awesome. Thanks man.
Old Mar 9, 2013 | 11:20 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
I replaced my pads at 50K --- yes, they were almost at the sensors.
BTW, I agree with most of the post above, except....
At 20K-50K range, my brakes made noises also but only when they were dirty. I quick weekly hosing made the noise disappear.
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
