help!
Old Apr 21, 2013 | 04:24 PM
gibbonsc4s's Avatar
gibbonsc4s has a spectacular aura aboutgibbonsc4s has a spectacular aura about
help!
Last couple of days I've noticed a decrease in power under acceleration, and some anemic starts.
Today the start took several seconds before the engine turned over.
While driving home, I went to pass some cars on a rural road and had even less power - enough that I knew I wasn't imagining things.
Also, te car seemed to rumble with acceleration.
Finally, I briefly got an orange check engine light that went out, and two blocks from home, the red engine light and "reduced engine power"
Temp was fine, oil level was fine.
Is this an alternator fail or something more serious?
I've got a tow booked for the dealership in the am, but I need some advice and a stiff drink to make it to tomorrow!
By te way, odometer reading is 113,000km on a new 2011 c4s.
Thanks and down the hatch.
Old Apr 21, 2013 | 05:24 PM
dethman's Avatar
dethman has much to be proud ofdethman has much to be proud ofdethman has much to be proud ofdethman has much to be proud ofdethman has much to be proud ofdethman has much to be proud ofdethman has much to be proud ofdethman has much to be proud ofdethman has much to be proud of
113k km on a 2011? ?
Old Apr 21, 2013 | 05:30 PM
gibbonsc4s's Avatar
Yes. :-) commute through country highways.
Old Apr 21, 2013 | 09:43 PM
holden997's Avatar
holden997 is infamous around these parts
what fault codes are you getting?
Old Apr 21, 2013 | 11:24 PM
lacrosse's Avatar
lacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud of
Could be a bad coil
