Wrap Removal
Old May 11, 2013 | 10:15 PM
RaidersR1's Avatar
RaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of light
Wrap Removal
I got a used bumper from a fellow 6speeder and its getting prepped and sprayed. My current bumper has a wrap on it...which I'm leaving on when removed. So when I put the new bumper it will not have a wrap. My hood and fenders however are wrapped and it is original with the car. The film is looking a bit old now and I want to remove it since the replacement bumper is not wrapped.
How hard or difficult will it be to remove the film from the hood, fenders and mirrors? Should I use a heat gun to warm it up? I fear the paint coming up...if that is a possibility.
Any help would be great.
Old May 12, 2013 | 06:45 AM
mto's Avatar
mto
mto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud of
I would not put film on a freshly painted bumper until the paint cures, which can be a month or two. Otherwise if you take the film off, the paint probably will lift.
To remove the film
First off make sure that nothing has been repainted on the car.
Suggest parking in direct sunlight and get surface hot, don't use heat gun. Suggest hair dryer or better yet, a steam machine. Pull old film off slowly and on a 45 degree angle. It should come right off.
After you remove the film you want to clean it up the leftover adhesive. I found 3M adhesive remover, clay, then polish to remove any surface swirls. Follow manufacture instructions for applying, which is probably cleaning area with rubbing alcohol.
Old May 12, 2013 | 08:38 AM
RaidersR1's Avatar
Thanks.....I will try on the door handles and the door edge first to make sure I get the "procedure" right before I tackle the hood and fenders.
The newly painted bumper will not get wrapped. I'm going to wait to have it done...if at all. I really don't drive the car very often....not a DD so spending the money on a wrap again is not what I want to do. Would rather spend on mods!!
Old May 12, 2013 | 11:39 AM
911Stud's Avatar
911Stud is infamous around these parts
Heat gun and pull as parallel to the panel as possible - never perpendicular to the panel, because this will put more stress on the clear/paint.
markj
911
Apr 7, 2016 05:44 PM
no1joey
Sep 9, 2015 01:30 AM
AM v12v
Sep 7, 2015 02:17 PM
Wildcat1212
Sep 7, 2015 11:31 AM
