oil leaking
Old May 24, 2013 | 06:53 AM
kkswow12's Avatar
kkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nice
oil leaking
I have just noticed slight oil creepage would be a better word, on the intakes on top of the engine...like not really leaking but you can see how the intakes have dampness coming from where they meet the rubber gaskets...anyone else seen/experienced this? and what to do...? also at the base of the hydraulic reservoir it is getting wet as power steering caps do... I do not run her hard, this also needs attention
Old May 24, 2013 | 07:25 AM
alpine-al's Avatar
alpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of light
Perhaps you've got a faulty Helmholtz resonator? (just kidding)
Old May 24, 2013 | 08:04 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
are you sure the intake stuff is oil and not PS fluid also? maybe you had a blowoff (or whatever it's called) from the overflow valve.
Old May 24, 2013 | 10:32 AM
kkswow12's Avatar
just been looking at tis and it seems to be blow by from where the gasses are re routed just behind the MAF, or drossenklapper...I think invented by helmholtz
Old May 28, 2013 | 12:02 AM
kkswow12's Avatar
does anyone else have this? I can't believe I am alone in this... is there a valve that maybe gets stuck/needs replacing? it isn't much but I can tell that it will get worse...
Wheeler
Sep 22, 2015 08:02 PM
carbonjim996TT
Sep 20, 2015 08:14 AM
Lucid Moment
Sep 12, 2015 01:12 PM
ECS Tuning - BMW
Sep 11, 2015 09:02 AM
ricks234
Sep 10, 2015 12:51 PM
