braking problems while turning
Old Jun 6, 2013 | 04:05 AM
dethman's Avatar
dethman has much to be proud ofdethman has much to be proud ofdethman has much to be proud ofdethman has much to be proud ofdethman has much to be proud ofdethman has much to be proud ofdethman has much to be proud ofdethman has much to be proud ofdethman has much to be proud of
noticed a new problem just over past month or so, whenever i'm turning and braking at the same time, which doesn't occur often, i notice that the brake pedal seems to shudder and sort of 'catch' in certain positions. it's difficult to describe. the actual brake functionign seems to be alright though. i checked the pads and rotors and they seem to be fine. there is no problem at all when braking in a straight line. any idea what this could be? car was braking fine previously. no changes other than new hankooks but in the same size as my prior tires. thanks for any thoughts...
Old Jun 6, 2013 | 05:20 AM
beemer guy's Avatar
beemer guy is a jewel in the roughbeemer guy is a jewel in the roughbeemer guy is a jewel in the rough
Are you causing the ABS to engage? Because that's what it sounds like from your description. The new tires may not have as much grip as the old tires. Especially brand new tires - there is often some release agent still on the tires that takes a few hundred miles to wear off. That makes the tires very slippery.
Old Jun 6, 2013 | 05:49 AM
wc11's Avatar
wc11 has a spectacular aura aboutwc11 has a spectacular aura about
You didn't mention hard or soft braking.
Under hard, the opposite wheel might be lifting just enough with less load to slip and thus the ABS kicks it.
Old Jun 6, 2013 | 01:29 PM
dethman's Avatar
new tires have 1500 miles on them already, they felt flighty at first (hankooks) but are more stable now. it happens under even medium braking, maybe not so much under soft braking. i've felt ABS before, when slamming on the brakes hard, and i think this feels a bit different. it feels like the brake pedal will get 'stuck' at one point and then 'click' down to the next level, like there's a catch somewhere. perhaps it is. also the traction control light does not come on during this type of braking either...
Old Jun 6, 2013 | 09:27 PM
RaidersR1's Avatar
RaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of light
I'm running Evos as well. Does this occur when you first drive off or shortly after? The negative of Evos is that they need to have heat in them before the grip starts. I get slippage during cornering when they are cold.
I've AutoX them as well and in between runs they col enough that its noticeable.
Hope this helps.
Jul 29, 2019 11:13 AM
Marcos AMV8
Dec 18, 2015 06:03 AM
LiquidElephant
Aug 27, 2015 06:17 PM
rnl
Aug 26, 2015 02:36 PM
