oil level check question
Old Jun 8, 2013 | 02:52 AM
DoninDEN's Avatar
DoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond repute
Old Jun 8, 2013 | 04:17 AM
slammp's Avatar
slammp is infamous around these parts
In truth it does not take a lot to reach that overfill mark. Last time I did my oil I made the mistake of following the porsche recommendation on refill capacity which is 8. Something. With the filter. It's too much. After I checked the level I had the same thing but I only had to pull about an eighth of a quart out to get the level perfect. Just loosen the drain plug but not all the way and let it run some oil into a pan. Not more than a small coffee cup full then tighten it up. Run the engine for 20 seconds. Shut it off and wait forever until the digital gauge can read again.
Old Jun 8, 2013 | 04:34 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
the op has an 07, I have an 09, he checks his level with the engine off and my 09 checks the engine oil level while running.... just a FYI.
mine was also filled like his when it left the dealer for the first time. as someone said, it s probably only a cup over. that shouldn t cause a problem.
Old Jun 10, 2013 | 11:46 AM
evhudsons's Avatar
evhudsons is infamous around these partsevhudsons is infamous around these parts
I like the idea of draining some oil but keeping it to top back off to the right level. It would be really bad to blow a seal.
thanks all, and I'll post my results later.
Jul 29, 2019 11:13 AM
tkebp1275
Aug 31, 2015 06:35 PM
The Oss
Aug 24, 2015 08:19 PM
