HELP My Key is Stuck in Ignition Even Though It Turns On and Off
Old Jul 27, 2013 | 12:49 PM
Perk10's Avatar
Perk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond repute
Exclamation HELP My Key is Stuck in Ignition Even Though It Turns On and Off
Hey guys,
Today I walked out to my car in the Subway parking lot and put my key in the ignition like I always do. I went to turn the car on and it would not do so. Naturally, I turned the key back counter clockwise and to my surprise it would not budge.
I called a Porsche friend of mine and he told me there is a key release next to the ignition area and I found it. I popped the small plastic piece off with a flat head screw driver and saw three small holes. I then took an alan wrench and played with it for 30 minutes. I felt absolutely no difference and stopped using it.
The car's dash lights up, the radio works, everything. It does not seem to be a battery problem at all!
I tried to jump it just in case and of course it didn't work. Then, all of a sudden my buddy hopped in and pressed the key really hard inward and got the car to start. I was scared to turn it back off but tested it and this time it wouldn't turn off! So I did the same thing he did and I pushed the key in really hard and attempted to turn it off and this time it worked.
So now, my car is in the garage safe and sound with the key completely stuck in the ignition, but as of now I can literally start and shut off the car as many times as I want just by pushing the hell out of the key toward the column as I turn it left or right.
Just in case something is up with the battery, I plugged it into my Porsche Tequipment battery tender and it is showing that the battery is completely full which I already know is not accurate because it never does that. Ever. I think it is confused because the key is in the ignition.
Please help me out here guys!! I did a search and saw that I am not the only person with this problem except everyone else seemed to have a problem with their battery or something like that. My car is completely fine, just the key is stuck.
Any and all help is MUCH appreciated!!!
Thanks,
John
Old Jul 27, 2013 | 02:50 PM
Robocop305's Avatar
Robocop305 is just really niceRobocop305 is just really niceRobocop305 is just really niceRobocop305 is just really nice
I heard that there is a mechanism in the key hole that often fails and its easy to fix and fairly cheap. Do a search on the internet and should find a topic regarding this issue. Good luck.
Old Jul 27, 2013 | 08:42 PM
Perk10's Avatar
there happens to be a mechanism in the key that allows me to pop the stuck key out, but I cannot even get that to work!
Has anyone had to pop their key out before??
Old Jul 27, 2013 | 10:46 PM
AreaOne's Avatar
AreaOne has a spectacular aura aboutAreaOne has a spectacular aura about
Old Jul 28, 2013 | 11:43 AM
Hold Steady's Avatar
Hold Steady is infamous around these parts
Take thee to a dealership...
You might be able to rectify the problem but you could cause additional problems.
IMHO.
NC 996TT
Mar 23, 2023 06:19 AM
pwdrhound
Sep 13, 2016 10:44 AM
BLKMGK
May 31, 2016 04:32 AM
BLKMGK
Sep 19, 2015 03:51 PM
Suds26
Sep 2, 2015 01:33 PM
