Low Brake Fluid Level
Old Aug 26, 2013 | 02:29 PM
Jophiel's Avatar
Jophiel is infamous around these parts
About a month ago I had a low brake fluid level warning appear in my 997.1 C2S. I took it into the dealer for them to take a look at the brakes and to fix the problem. According to the dealer, the fluid was just low and they topped off the level free of charge.
Fast forward to today. The light came on again. I looked at the level as per the owners manual and sure enough, the level is just below the "min" marker.
Here's the question: Is it common that a 997.1 should loose brake fluid? I should also mention that I tracked the car for about 10 laps around mid-ohio last week, but I didn't push it too hard. I've never had a brake fluid level warning in any other car before, let alone twice in about a month.
In a pinch, can I top off the fluid level with any generic brake fluid? The dealer is about an hour away and I would like to save myself a trip if possible.
Thanks!
Old Aug 26, 2013 | 04:38 PM
Robocop305's Avatar
Robocop305 is just really niceRobocop305 is just really niceRobocop305 is just really niceRobocop305 is just really nice
Have you noticed any leaks? What about pad wear?
Old Aug 26, 2013 | 05:01 PM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
I think you likely have a leak somewhere. I've never experienced this with brake fluid. Somewhat common with oil though.
Old Aug 26, 2013 | 07:20 PM
Lugs H's Avatar
Lugs H is infamous around these parts
Besides checking the brake components you should also check your clutch slave cylinder. It is also connected to the brake fluid reservoir.
Old Aug 26, 2013 | 08:50 PM
Jophiel's Avatar
Actually, checking my records, it has been more like 4.5 months since the last top off of fluid. Still, I wouldn't think it would really need any additional fluid absent a leak.
Old Aug 27, 2013 | 08:37 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
shouldnt leak at all. check your reservoir - and i would take off the frunk panels so you can inspect underneath it too.
Old Aug 27, 2013 | 11:00 AM
ECS Tuning - Porsche's Avatar
There has to be a leak somewhere. You could pressurize the system with something like a Motive Brake Bleeder, and look for leaks starting with the master cylinder, then the reservoir, slave cylinder, ABS hydraulic unit, all 4 calipers, and all of the lines in between.
Old Aug 27, 2013 | 11:15 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
also look in the foot well area by the clutch pedal and under that rug.. I had a 944 once that leaked In that area from the clutch.... you really shouldn t be using that fluid... anyDOT 4 to top t off unless you know what s in there already.
Old Aug 27, 2013 | 03:05 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Brakes fluid should never be " topped off " and am surprised the dealer did it. Brake fluid level will go down as pads wear but not to the point of needing more fluid. As others have already stated, the system is leaking and needs to be checked out ASAP by a competent mechanic.
Old Aug 27, 2013 | 04:22 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
As they said, it should go low only when your pads wear out.
You should probably find out where the leak is ASAP. Brake fluid can really damage metal finish really fast!!!!
Old Aug 27, 2013 | 04:24 PM
cerbomark's Avatar
AND if the level goes too low you will get air in the system causing an unsafe condition.
Old Aug 27, 2013 | 05:58 PM
cab83_750's Avatar
Silly question but are your pads down again?
Old Aug 28, 2013 | 11:23 AM
Jophiel's Avatar
Pads are like new. In fact, before this problem, a different dealer looked at my brake pads and rotors to try and diagnose a vibration at speed/braking (turned out my lugs were torqued too tight). Dealer said the brakes looked like the car had never been driven hard.
Old Aug 28, 2013 | 05:54 PM
cab83_750's Avatar
Others may have another ideas but if you can't find the leak, here's what I would do:
Go buy the blue-colored fluid. Flush your system and ensure it is flushed correctly. Watch and see if you go low again. If you go low again, at least you would find blue fluid wherever the leak might be.
Did you buy the car new? CPOd? As I said, fluid is very damaging so take care of this quickly.
Ps,
When you tracked your car, I wonder if you hit boiling point?
audipwr1
Sep 25, 2021 01:31 PM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
