Help on Front Bumper LED
Old Sep 13, 2013 | 03:14 PM
lazyseoul's Avatar
lazyseoul is infamous around these parts
So I received my front bumper LED lights for my '08 997 C4. The fog light and turning lights were plugged seamlessly but the DTR plug doesn't fit. There seems to be a piece in the socket attached to the car that won't let me plug into the light housing.
I have also attached photo on said plug.
Has anyone run into a similar situation when they were installing these lights?
If you have, did you just return the lights or did you do some sort of hack?
Any advice would be greatly appreciated.
Old Sep 18, 2013 | 07:29 PM
2fas4u's Avatar
2fas4u is infamous around these parts
Cool connectoins
You will need to use your plug from you oem lights on that one in the picture and the one with the yellow bulb. remove the bulb put use the seat and they should connect. The third one with the harness will connect right up although not as good as the oem but will hold. cheers they look good too.
Old Sep 24, 2013 | 08:19 PM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
When I did mine, I scotch-locked the wires from the DRLs onto the OEM wires so I didn't have to cut the plugs off either the OEM lights or the car wiring. If I wanted to reverse the mod, I'd just undo the scotch-lock and tape over or seal the tiny area of the car wiring where it had been connected. Been running them this way for 18 months - no problems. By not cutting the plugs on the OEM lights, I was able to sell them on the Forums to help defray the cost of the LED upgrade.
Old Sep 24, 2013 | 11:12 PM
martidamm's Avatar
martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !
Originally Posted by lazyseoul
So I received my front bumper LED lights for my '08 997 C4. The fog light and turning lights were plugged seamlessly but the DTR plug doesn't fit. There seems to be a piece in the socket attached to the car that won't let me plug into the light housing. I have also attached photo on said plug. Has anyone run into a similar situation when they were installing these lights? If you have, did you just return the lights or did you do some sort of hack? Any advice would be greatly appreciated.
I did that mod on my car, on the original lamp remove the socket then remove the bulb and that connects into the led connector and then back into the new lamp.
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
Steven997TT
Aug 27, 2015 02:56 PM
TrackOne
Aug 20, 2015 12:56 PM
Nissan GTR
Aug 19, 2015 02:11 PM
