Rear Fog Light Bulb
Old Nov 8, 2013 | 01:33 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
Originally Posted by jhbrennan
That's the only side that works. Passenger side is not connected even though there's a bulb in the socket.
That seems very 'unporsche' .. to install a bulb in a socket that isn't even used. I mean, this is the company that custom builds wiring harnesses to save (or is it prohibit) on a bit of weight.
Is that opposite side just the 'spare holder'?
Old Nov 8, 2013 | 01:35 PM
Minok's Avatar
Originally Posted by carrera997re
Some leo thats clueless was going to write me up for blown tail light i told the guy its a rear break light (was rainy and misreble out) he wouldnt believe me
Heh? Blown tail light.. if you have the headlights on, both tail-lights are illuminated.. easy enough to see.
Press on the brakes, all 3 brake lights come on. Easy to see.
Was his issue (it seems so) only that you had one light on one side, without a corresponding equal light on the other side?
I mean, how would he right that up - a blown light that I'm not sure what it is as I verified the tail and brake lights are working?
Old Nov 8, 2013 | 01:36 PM
jhbrennan's Avatar
Passenger side fog light socket has a bulb...but no power ever gets to it.
Old Nov 12, 2013 | 02:03 PM
Minok's Avatar
Right... and that seems very odd. (as a very odd thing for them to be doing.. not that they are not doing it... just doesn't fit the character of the company in my view)
Even if they do that so one can reconfigure the fog light feature in the computer to determine which lights come on or not.. to install a part that isn't needed is very un-Porsche, given their bespoke solutions to everything else (wiring harnesses, PCM components, etc).
Old Nov 12, 2013 | 05:39 PM
p's pcar's Avatar
p's pcar is infamous around these partsp's pcar is infamous around these parts
Power does get to the right side fog socket. Both sides also act as the parking lights. Both fog lights and brake lights are the same bulbs. They both have a low setting and a bright setting. When you turn on the fog light or step on the brake, the bright setting is activated. I had a "brake light out" warning light and realized the low setting still worked. It was late enough at night that I couldn't get a replacement so I simply changed the bulb with the right fog bulb and everything worked fine.
Old Nov 13, 2013 | 01:59 PM
Minok's Avatar
Ah, ok. That makes sense.. its not a separate bulb, just the activation of a separate filament in an existing bulb. Though I'd think if the rear fog and brake are the same bulb, then if you are in the places with dual rear fog illumination, seeing when the brakes are applied relies entirely on the 3rd brake light, which sounds risky.
Old Nov 13, 2013 | 02:32 PM
jhbrennan's Avatar
You're still confused - the fog light bulb/socket is separate from the brake light bulb/socket...but both sockets use the same type of dual filament bulb. The fog light acts as a parking light until the fog light is activated at which time the extra, brighter filament illuminates, although only on the driver's side. So the brake lights aren't affected.
Old Nov 13, 2013 | 07:46 PM
p's pcar's Avatar
The fog lights only illuminate on the driver's side so they're not mistaken for the brake lights.
Old Nov 14, 2013 | 05:24 AM
Ran ran's Avatar
Ran ran is infamous around these parts
I like to turn this on when I have a tailgater - they usually get the point
Old Nov 14, 2013 | 07:44 AM
SFZGT3's Avatar
SFZGT3 is infamous around these parts
That's 1 of 2 good uses for the rear fog lamp. The only other one is for truly inclement, low visibility conditions. Too often, I see "drivers" in high dollar Euro cars tooling down the highway in clear, normal conditions with their rear fog lit. Annoying and distracting to following drivers and seemingly "reflective" of the driver's ego.
Rant over!
Old Nov 14, 2013 | 08:24 AM
jhbrennan's Avatar
Just move over - much safer.
The_Ruski_Driver
Oct 25, 2015 08:40 PM
metzkaro
Aug 24, 2015 02:59 PM
ECS Tuning - BMW
Aug 21, 2015 02:00 PM
ECS Tuning - BMW
Aug 21, 2015 01:47 PM
Jeff1smith
Aug 19, 2015 09:41 PM
