Ashtray lid replacement
Old Jan 11, 2014 | 10:11 PM
Jgpapillon's Avatar
Jgpapillon is infamous around these parts
Does anyone know if it is possible to purchase an ashtray lid replacement for an 06 997? There is nothing wrong with the lid itself or the ashtray, except for that pesky Porsche paint. Does Porsche sells the paint? Probably not..
I would consider a ashtray delete, is the dealer the only purchase option?
Thank you for any feedback
j
Old Jan 11, 2014 | 11:32 PM
Buddhamonk's Avatar
Buddhamonk has a spectacular aura aboutBuddhamonk has a spectacular aura aboutBuddhamonk has a spectacular aura about
http://www.suncoastparts.com/product...e=997s_intcare
haven't been able to find the lid only
Old Jan 12, 2014 | 01:16 AM
IslandS62's Avatar
IslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of light
$189!?
Old Jan 12, 2014 | 07:07 AM
JB in AR's Avatar
JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !
I believe there's a Porsche dismantler in LA that might have a replacement. They advertise from time to time in Panorama. You can also get Behr paint to match in small sample batches at Home Depot.
Old Jan 12, 2014 | 07:37 AM
StormRune's Avatar
StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !
If your ashtray lid is black, there is an easy solution (and it's free!). Here's what I did:
It's pretty easy to remove the ashtray lid. Put it in a sink with hot water, not hot enough to burn you, using just normal hot water from the tap. Leave it sitting for just a minute or so to heat up, then rub the surface vigorously with your thumbs and fingers, pressing fairly hard while rubbing. The remaining coating will flake off pretty easily (at least it did on my 2006), no solvents are required. Gentle use of your fingernail will take any tough spots off easily, but don't use your fingernail too aggressively to prevent scratching.
It took me around 5 minutes to remove all of the coating. The underlying black plastic looked good. It has a mild and even surface texture. Reinstall after drying. I thought it ended up just fine, much better than it did with scratched up coating and it didn't stand out as being incompatible with the remaining console. I even considered doing this to the rest of the console but never did.
If you don't like it, it's no big loss since you are planning on replacing it anyway. Of course, attempt this at your own risk! Note that if you console isn't black this doesn't help you.
I took the attached photos when I did this. You can see how the coating just flaked off in chunks. Notice the resulting surface sheen is pretty flat and even.
ID:	320454   Click image for larger version
Old Jan 12, 2014 | 08:54 AM
FlaHeel's Avatar
I'm pretty sure there is a DIY somewhere on this site that tells the paint codes and translates that into either Home Depot or Lowes paint codes so you can paint the ashtray save the $$.
Old Jan 12, 2014 | 03:56 PM
ACRB's Avatar
ACRB is infamous around these parts
Did the same thing on the ashtray lid, and it worked perfectly. The light scratches on the center console are a different story. But I guess if you can remove the console, there is no reason why that couldn't be stripped as well?
Old Jan 12, 2014 | 04:37 PM
StormRune's Avatar
I would suggest trying the stripping method I described earlier before trying anything like paint. I'll bet you like it that way, and if not, you'd have to strip it anyway to get the paint to stick well. Free is good especially when it looks nice.
Old Jan 12, 2014 | 05:26 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond repute
You can also check with your local highline dealers and nail down the guy who fixes leather/plastic on CPO cars - these guys when skilled and experienced enough know how to spray the soft touch to re-do these parts, and often can do it in under an hour.
Old Jan 12, 2014 | 06:40 PM
Bokchoys's Avatar
Bokchoys is infamous around these parts
If you want to try fixing it yourself, you can do something like this:
http://forum.e46fanatics.com/showthread.php?t=753372
Old Jan 12, 2014 | 08:54 PM
Jgpapillon's Avatar
It is a shame that plasti dip only comes in black. Would be nice to have beige....thanks for the post.
j
Old Jan 12, 2014 | 09:05 PM
Jgpapillon's Avatar
Thanks Sportrune, Mine is beige but the plastic is beige also, so it will not be a problem but first I will try to obtain matching paint from Lowe's or Home Depot. Thank you for the tip it looks easy enough for me to tackle.
Old May 4, 2014 | 11:20 PM
gavc's Avatar
gavc is infamous around these parts
How did you go?
Does the beige look ok stripped? I have the same problem on my center console and looking for ways to fix it.
Old Apr 19, 2016 | 04:42 PM
MK23's Avatar
MK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud of
Sorry to revive a dead thread but I had the same problem with my ashtray lid on my sand beige interior turbo. For any other 6speeders wondering, pulling it out and scraping off the peeling paint under running water works great! It has a very slight sheen (compared to the original) that only a very trained eye at a certain angle could notice but otherwise, blends in very well. $189 + shipping isn't worth it for just a peeling lid. Anyway, my 2 cents FWIW.
Old Apr 19, 2016 | 05:36 PM
stevepow's Avatar
stevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of light
No kidding and it's going to peel also eventually!
