Will TPMS affect PASM?
Old Feb 23, 2014 | 08:16 PM
Cabrera S's Avatar
Cabrera S is infamous around these parts
First post...!
Long story short... Bought a 997 S (2008) with H&R suspension ( mod. 29188-1). This one says on the H&R site that is "ok with Pasm". TPC indicates that it is learning and will not read the left tires. It also continuously indicates that PASM is not working. Sport mode will activate but when the car moves PASM error will come up. Today I noticed that if I press the SPORT and do not clear the TPC error, PASM would stay "working"... This is very strange....
Has anyone else has had a similar scenario?
PS. I have the original springs and am thinking of installing them back, just want to know if I should go with the originals or keep the H&R and look for something else....
Great forum, keep it up...!
Old Feb 24, 2014 | 08:38 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
TPMS has nothing to do with PASM and neither will interfere with the other. it's possible during install that some wires to one or both systems were cut/damaged (or left unplugged?
Old Feb 24, 2014 | 09:01 AM
kcheves's Avatar
kcheves is infamous around these parts
Agree that the TPMS problem is unrelated. The batteries in the pressure sensors are good for about 6 years, so the timing is about right for replacement in a 2008. Search for posts on "TPMS replacement" for the name of a company that sells replacement sensors that work well and are a fraction of the OEM part's price. I'm hesitant to post the vendor's name since they appear to no longer be a forum sponsor.
As for the PASM error message and the strange interaction with the TPMS error messages- Are you reading the errors in the INFO screen in the OBC (accessed with the lower stock to the left of the steering wheel), or on the small display below the tach? And which PASM error are you getting? "PASM failure" or "PASM indicator faulty"?
Old Feb 24, 2014 | 10:34 AM
Cabrera S's Avatar
I'm reading them at screen below the tach, it indicates "PASM failure". When the car is turned on nothing happens (everything works fine...) until the car moves, then the fault appears. I've read here on the forum that usually that fault is associated with changing the suspension springs, but that H&R model is supposed to be compatible.
Old Feb 24, 2014 | 10:54 AM
kcheves's Avatar
I'll hypothesize that the behavior where the PASM error does not occur if the TPMS fault is not cleared may be due to the screen below the tach only showing one fault at a time. A tire pressure fault would be critical, so this message may be prioritized for display over a PASM failure. If you were to go into the INFO screen in the OBC, you'd probably find that the PASM fault is still there, along with the TPMS fault.
Good luck sorting this out. I checked, and the owners manual says to take it to a dealer if you get the "PASM failure" fault code.
Kit
San Diego
Old Feb 24, 2014 | 12:04 PM
Cabrera S's Avatar
Ok, thanks all for the information.
need4speedmotors
996 Turbo Vendor Classifieds
Jan 12, 2016 05:41 PM
freddiemac
Oct 7, 2015 11:05 AM
RajuPatel
New Member Introductions
Oct 2, 2015 03:28 PM
Street Fighter
Sep 28, 2015 05:31 PM
need4speedmotors
997 Turbo Vendor Classifieds
Sep 28, 2015 04:47 PM
