does it really matter which bleeder valve is opened first in flushing, outer or inner
Old Mar 8, 2014 | 02:45 AM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
does it really matter if the inner bleed valve or the outer bleed valve is opened first when flushing the fluid in the brake system. from the copy of the manual i have it does not specifically say which one shouyld be done first. i just did my brakes starting with the outer then the inner valve and all seem good. comments
Old Mar 8, 2014 | 05:24 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
I was instructed inside then outside last. Don t know how much it matters???
https://www.6speedonline.com/forums/...uid-flush.html
Old Mar 8, 2014 | 06:51 AM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
Inside-Outside. Clear the air in the middle of the system, then push bubble free air to the rest of the system. Wastes less fluid this way too.
It still works the other way around, but there is a small chance a tiny amount of air gets trapped in the middle of the system. When swapping the entire caliper I do outside-inside-outside. The first outside bleed is a quick one just to get fluid into the majority of the internal cambers. Then follow up with the traditional inside-outside bleed order.
Old Mar 8, 2014 | 07:05 AM
Hmmm, it does say inner bleed valve first in our diy....
Old Mar 8, 2014 | 07:25 AM
semicycler's Avatar
The more important piece is to work on the caliper farthest away from the master cylinder first. RR, LR, RF, LF in that order for LHD vehicles.
Within a caliper the inside-outside method is preferred. This way you "finish" at that corner farthest away from the master cylinder.
Old Mar 8, 2014 | 03:35 PM
But dont we want to finish at the valve nearest the ms with logic saying we start at the farthest and finish at the nearest?
Old Mar 10, 2014 | 10:53 AM
sullivas's Avatar
sullivas is infamous around these parts
Tap the caliper with soft faced hammer to free up the small bubbles that cling to the inside while bleeding..tip from PFC expert at Club seminar.
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
alwaysbored786
Apr 19, 2016 05:51 AM
shifter_
Sep 8, 2015 12:07 PM
