997 engine bay fan
Old Mar 29, 2014 | 11:25 PM
no1joey's Avatar
no1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to all
997 engine bay fan
Hi all, just introduced myself on the intro thread, glad to be here.
I just picked up a 2005 tiptronic C2S Cab with just 35,000 kms (21,000 mls) on the clock in midnight blue, used to own a midnight blue 996 Carrera 4 Cab.
I have an issue I think with the engine bay fan, I have read all the threads on this issue, but I haven't found an answer that helps me.
The engine bay fan never comes on unless the key is in the ignition and the power is on. Some people complain that the fan doesnt stop after the engine is stopped, my issue is the opposite.
When back from a long hot drive, the fan is on, I turn off engine and the fan stops. If i turn the power back on in ten or twenty minutes the fan comes on straight away.
It seems to me that fan wants to be on, but can't without power from the ignition on.
It has just been serviced and I asked this question and the Porsche technicians answer was it has a mind of it's own it does what it needs to do there is no set pattern etc'...
What do you guys think? I am going to have the engine bay temp sensor replaced just in case.
Cheers guys thank for your help!
Old Mar 30, 2014 | 06:07 AM
Matt(inMA)'s Avatar
Matt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud of
I have an '06 and the fan has never stayed on after turning the car off.
Matt
Old Mar 30, 2014 | 07:16 AM
wc11's Avatar
wc11 has a spectacular aura aboutwc11 has a spectacular aura about
My 05 has stayed on occasionally when the car is turned off. Presumably to cool to what is deems to be safe.
It's thermally controlled so engine is not deemed too hot if fan is not on.
Old Mar 30, 2014 | 07:19 AM
barncobob's Avatar
barncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the rough
06 when I turn the key off the fan goes off, have never heard it running w/o key in,,,its gets hot here in CA
Old Mar 30, 2014 | 11:27 AM
eldertec's Avatar
eldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to behold
Mine turns off like yours.
Never really thought about it...Porsche knows best.
Don't worry about it.
Old Mar 30, 2014 | 04:06 PM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
Yes mine turn off when you turn off engine. However, if it was after a good run, after a while, even without the keys on ignition, the fan turns on by itself. There is a monitoring sustem of the engine compartment temperature for 30 minutes after turning off the engine. If the system deems it too hot, it turn on the fan for a few minutes to bring temp down to threshold.
Old Mar 30, 2014 | 05:01 PM
no1joey's Avatar
hmm seems ok then, I have come back from really hot drives but I do park in a cool underground parking space, and the ambient temp outside hasn't been above 28 degrees c (82 f) since I owned the car which is going on two weeks.
Old Mar 30, 2014 | 07:56 PM
eldertec's Avatar
Saw a Great Porsche video of testing in like...Africa.
I don't think we need to worry.
Old Mar 30, 2014 | 11:55 PM
no1joey's Avatar
Nice.
Old Mar 31, 2014 | 07:12 AM
Phil_D's Avatar
Phil_D is infamous around these partsPhil_D is infamous around these parts
X2 My fan turns off nearly all the time when I turn the ignition off. Very occasionally it will stay on or come on, especially when it is 100°F+ outside.
Old Mar 31, 2014 | 07:56 AM
wc11's Avatar
"yeah but it's a real dry heat"
Old Mar 31, 2014 | 10:46 AM
StormRune's Avatar
StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !
Agree with all of the above, my 2006's fan would generally only come on when the car was off if the outside temp was in the mid 90s or higher.
Jul 29, 2019 11:13 AM
turbotuner20v
Sep 11, 2015 12:02 PM
Glasig
Aug 23, 2015 03:35 PM
Aug 21, 2015 09:56 AM
