Weird mirror issue....
Old Apr 29, 2014 | 07:51 PM
ACRB's Avatar
ACRB is infamous around these parts
Just picked up my car from the mechanic. Stopped to get it washed, brought it home and noticed this strange mark inside the mirror. I don’t believe its moisture…………. It wasn't there when I picked up the car. Once again, any input is greatly appreciated.
Old Apr 30, 2014 | 06:24 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
I really can t see much in this pic.... did u try a cleaner on the glass to see if it cleans off?
Old Apr 30, 2014 | 07:07 AM
Domer911's Avatar
Domer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond repute
my wife won't iron my shirts, either
Old Apr 30, 2014 | 07:48 AM
Burg Boxster's Avatar
Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !
Actually does look a bit like moisture seeped b/w and is on the back of the laminate/between the surfaces. Try stuffing a paper towel up under the leading edge around mirror to wick the moisture/cleaner back out. Might also mark the outer edge of marked area on mirror surface using a crayon or dry erase marker to see if it spreads/reduces.
LOL - not helpful to OP but funny none the less!
Old Apr 30, 2014 | 07:54 AM
cerbomark's Avatar
Ok, now see what you are talking about. does look like condensation as stated above. Should go away on a hot day if that s it.
Old Apr 30, 2014 | 08:29 AM
martidamm's Avatar
martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !
i think your mirror might be done for, it's self dimming, this happened to me on a suburban rear view, can't be fixed, only replaced, the liquid used to dim the mirror has leaked, sorry.
Old Apr 30, 2014 | 08:53 AM
cerbomark's Avatar
any warrenty on the car?
Do you think the dealer did a mirror swap while your car was there.?
Old Apr 30, 2014 | 10:24 AM
ACRB's Avatar
Well... I guess that's two things on the list, a new dry cleaner/laundry and a new mirror!
Old Apr 30, 2014 | 10:26 AM
ACRB's Avatar
No, it's classic...recently came off the CPO and little things are breaking on it.
Old Apr 30, 2014 | 10:42 AM
barncobob's Avatar
barncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the rough
maybe use a hair dryer on low heat
Old May 1, 2014 | 09:36 AM
lenelsa's Avatar
lenelsa is infamous around these parts
I think I see Jesus.
Old May 1, 2014 | 10:26 AM
martidamm's Avatar
jesus?? He will be on the expensive replacement bill
Old May 1, 2014 | 02:13 PM
PSPorsche's Avatar
PSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond reputePSPorsche has a reputation beyond repute
I agree. I think the technology is similar to the "Liquid Crystal Displays (LCDs)" and once that stuff leaks out, the unit is damaged.
Old May 1, 2014 | 03:27 PM
ACRB's Avatar
That's exactly what it is. I did some research and it seems to be prevalent in BMW's. The liquid is supposedly highly caustic and can drip out and really cause havoc. Just a real idiotic pain in the A#s. I mean before you could be in a 993, and not worry about some goop dripping on your kneecaps, or worse yet the dashboard. (Also, the only apparition in the mirror is me in a wrinkled Ralph Lauren shirt..... sorry to disappoint).
Old May 12, 2014 | 01:19 AM
JGlover's Avatar
JGlover is infamous around these parts
Lololololol
navtool.com
Lexus Vendor Classifieds
Oct 1, 2015 11:14 AM
navtool.com
NY Tri State
Oct 1, 2015 11:13 AM
navtool.com
navtool.com
Oct 1, 2015 11:10 AM
navtool.com
BMW Vendor Classifieds
Oct 1, 2015 11:09 AM
