AUX audio connection for PCM 3 - what kind of connection?
Old May 14, 2014 | 12:20 PM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Originally Posted by Bruce in Philly
My car came with a special iPod cable... I never used it, but it is a special iPod cable..... I think it has its own socket next to the USB socket... IIRC
Peace
Bruce in Philly
Yes, I've been using that dedicated porsche cable.
Old May 14, 2014 | 02:31 PM
Johnny DB's Avatar
Do you know anyone who sells a longer cable? The one from Porsche is too ****ing short!
Old May 14, 2014 | 04:56 PM
ryem3's Avatar
Lol, what are you going to do with a longer one? Try suncoast.
Old May 14, 2014 | 08:11 PM
ryem3's Avatar
Originally Posted by cab83_750
Based on my experience, nothing beats the Ipod connections -- even the aux.
Got that right! Well, figured it out and it might help others. When you go to the DISC menu on the PCM 3, there is an OPTIONS tab. When you select the tab, there is a box to enable the AUX input. If you don't enable it, it doesn't work!
I enabled it and it sounds HORRIBLE. Unbelievable. Also, there is no interface whatsoever. You need to control everything from the unit itself. So, my hi rez player is a total waste for the car. The iPod line in is a MUCH better interface. Not only is the line in sound input much better, you get a full readout on the screen, with artist, album and song. Looks like I'm getting a new iPod classic and getting rid of the hi rez player, it's not worth it.
Not at all... I have a 64g usb stick in there right now filled up with 360 MP3 music. The interface is clunky and it takes some time to "read" the directory etc... but it works well. You may try using it.
It absolutely won't read lossless or high-rez files. Just won't. I did a ton of research and listening tests and I found 360 fixed bit rate MP3s ripped with a LAME encoder sounds best. I was shocked that it really is acceptable.
Peace
Bruce in Philly
I highly recommend ripping a good CD using ALAC or AIFF to your iPod and use a cable into the car. I think you'll really like the results. You have PCM 3 right? I don't recall. You'll also get the huge benefit of a usable interface on the PCM screen.
Old May 15, 2014 | 12:28 AM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
...my hi rez player is a total waste for the car. The iPod line in is a MUCH better interface. Not only is the line in sound input much better, you get a full readout on the screen, with artist, album and song. Looks like I'm getting a new iPod classic and getting rid of the hi rez player, it's not worth it....
One thing to not forget: ever since the Apple products came out, a lot (if not the majority) of car audio manufacturers started to "engineer" their units to be fully compatible ("maximized) with the Apple products (ipod, iphone, etc.). I once bought a Clarion unit and it played Iphone music wonderfully.
I was following your hi-rez adventure since I am always open-minded. Sorry about the results.
Old May 15, 2014 | 09:02 AM
Johnny DB's Avatar
The iPhone doesn't fit very well in the arm rest portion. I want to keep it in the hole in front of the shifter.
Old May 15, 2014 | 01:42 PM
ryem3's Avatar
Go to Parts Express and look for a 32 pin to 32 pin extension. I'm sure they have one. You'll never find the odd pin Porsche connector in a longer length.
Old May 16, 2014 | 10:16 AM
Johnny DB's Avatar
Thanks, didn't think about an extension...sometimes wonder where my mind is.
Will I suffer a quality loss?
Old May 16, 2014 | 10:32 AM
Bruce in Philly's Avatar
Bruce in Philly is a glorious beacon of lightBruce in Philly is a glorious beacon of lightBruce in Philly is a glorious beacon of lightBruce in Philly is a glorious beacon of lightBruce in Philly is a glorious beacon of lightBruce in Philly is a glorious beacon of light
All depends if it is a digital stream or not. If analog, those cables introduce noise and all kinds of nasty degradation. If it is digital.... it either works or not - usually.
Peace
Bruce in Philly
Old May 16, 2014 | 11:53 AM
ryem3's Avatar
Peace
Bruce in Philly
Good point. For this it is an analog out since we don't have any DAC processing in the car. For this application, the degradation should be minimal. The convenience should overcome the loss. If it were a Bentley, you might notice the difference!
Old May 16, 2014 | 12:03 PM
cab83_750's Avatar
Has anyone played/experimented with this DAC for their cars? I have the home model one for the home audio, and I like it. I was going to try it for the 997 but I just had not had the time.
Amazon.com : HRT - Istreamer - Outboard DAC for Idevices 12v Version : MP3 Players & Accessories Amazon.com : HRT - Istreamer - Outboard DAC for Idevices 12v Version : MP3 Players & Accessories
Old May 16, 2014 | 01:33 PM
Johnny DB's Avatar
Peace
Bruce in Philly
Thanks for the input.
Old May 16, 2014 | 06:39 PM
ryem3's Avatar
Video Link: http://www.amazon.com/HRT-Istreamer-Outboard-Idevices-Version/dp/B005STHR2W
Hmm. Tricky with these devices. Tough question if this is really a dac or not. I'm not even sure if there are digital outputs on an ipod. I used a Wadia ipod dock for a while and found it was really pretty mediocre.
Old May 16, 2014 | 07:25 PM
larrytrk's Avatar
larrytrk is infamous around these parts
Old original Porsche iPod cord, no usb included + iPhone 5S + 30 to 10 pin converter
Equals a PCM3 with a buzz, then, no sound at all, stuck in AUX.
Did not reset until plugged into dealer laptop PIWIS.
Old May 17, 2014 | 10:11 PM
cab83_750's Avatar
FYI, before this unit my IPod music sucked pretty bad coming from the Martin Logan's. One of my better investments.
Thus, I was going to try the car unit.
Similar to you, I don't know if the iPhone has digital out.
