Help with tires cupping/cutting - 997S with Turbo 997.1 wheels and 305s.
Old May 24, 2014 | 10:08 PM
blakt out's Avatar
blakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond repute
Hey everyone,
First of all, long time, no talk. I'm back in a 997S now. It came with real turbo wheels on it (2S car). They are the real forged 19X11 (my only issue is rear, so I'm only talking rear here). I put set of Bridgestone RE-11s on (305/30-19) in October. I've been smelling burning rubber for a while and had no idea why. Well, I think I found it. I took the wheels off today to swap out the spark plugs and for my FD muffler install, and the inside 3/4 inch of both were CORDED. Way too early. I can't see what they would be hitting though. Any help? I just ordered another set of 305s today from TireRack, but would it be fixed it I went with 295s? Is it an offset issue where I just need to get new wheels?
Any help is very appreciated. Thanks much, and I'm glad to be back!
Jared Cullop
Old May 24, 2014 | 11:00 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
You should go to a tire shop and have them evaluate your off set and wheel/tire width. You obviously have a problem that needs to be looked at in person. Not enough information contained in your post to even get close.
Old May 24, 2014 | 11:07 PM
Anderson's Avatar
Anderson is infamous around these parts
Do you feel/hear any running at low speeds? Lot of people here have 305s on 11"rims, not sure about turbo wheels offsets..
Old May 24, 2014 | 11:37 PM
gordon9898's Avatar
gordon9898 is a jewel in the roughgordon9898 is a jewel in the roughgordon9898 is a jewel in the roughgordon9898 is a jewel in the rough
Isn't the problem that the rear turbo wheels are meant for widebody porsches and you have them on a narrow body Porsche?
Old May 24, 2014 | 11:50 PM
Buddhamonk's Avatar
Buddhamonk has a spectacular aura aboutBuddhamonk has a spectacular aura aboutBuddhamonk has a spectacular aura about
I have wide body wheels on my narrow body c2s and 305 tires - no problem with rubbing. I think you have an issue with your alignment
Old May 25, 2014 | 12:25 AM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
As recommended above, get yourself an alignment/suspension check.
Note that 'some' tires are prone to cupping.
OOC, what brand of tires do you have in the front?
Old May 25, 2014 | 03:06 AM
cool flash's Avatar
cool flash is infamous around these parts
Narrow body has 11x19 with ET 67 on rear.
Turbo runs 11x19 with ET 51 on rear.
Difference of 16 millimeters is more than half an inch. Together with the 305 may well cause rubbing.
Regards,
CF
Old May 25, 2014 | 08:27 AM
blakt out's Avatar
Right, cool flash. That's what's concerning. Plus, the smell of burning rubber from both wells. I'll post a pic of them up asap. It's less like cupping and more like being cut and formed gradually to go around something that is hard and immovable. Thanks for all the help, fellas.
Old May 25, 2014 | 05:32 PM
Anderson's Avatar
If it was rubbing a lot then you would feel it, and if it is rubbing just a little then alignment may fix it.
Old May 25, 2014 | 07:26 PM
simoncpw's Avatar
simoncpw is a jewel in the roughsimoncpw is a jewel in the roughsimoncpw is a jewel in the rough
My C2S is running the 19"x11J Turbo Style for the rear. The offset is ET67 for the rear and running 305 without any issue. I took the wheel out last week to double check the offset, and the tire wearing looked fine.
May be first is to confirm the exact offset of your wheels, if it is indeed ET51, it should extend outward by 16MM... giving MORE clearance on the inside.
I'm tried fitting another set of wheels with ET48 for both front and rear last week and they were fine too.
Old May 25, 2014 | 09:15 PM
blakt out's Avatar
Mine are definitely ET51. I get what you're saying, and will take it to a shop (if one is open) tomorrow. Otherwise, I'm buying some wheels and tires immediately.
Old May 25, 2014 | 09:26 PM
simoncpw's Avatar
Can you post a photo showing the "CORDED" location?
Old May 25, 2014 | 10:34 PM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
I run wide body 19x11 ET 51's on a narrow body C2S with 305 tires. No rubbing. Others run narrow body 19x11 ET 67'x with 15mm spacers on a narrow body C2S with 305 tires. No rubbing.
Inside edge wear on both sides means alignment or suspension problem. Are you lowered on aftermarket springs or coilovers? Was an alignment done afterwards to correct the excessive camber from dropping the car? Excessive Inside wear on both tires happens when dropping without correcting the camber change.
Old May 25, 2014 | 11:00 PM
blakt out's Avatar
Thanks guys. I really appreciate the help. The car is on factory PASM. No lowering. That's the shocker. Both sides are being cut equally, but I couldn't get a good pic of the driver side. Just assume it sucks as much. You can tell a bit in the bottom pic, but it literally has a right angle cut out of it.
Old May 25, 2014 | 11:09 PM
semicycler's Avatar
That's not camber wear, that's rubbing. Something is really off with those wheels. Do you have ramps you could put the car on? You want to be able to get under the car with weight on the wheels to see what is touching. And don't despair yet, this could be fixed with spacers.
How flush is the outer edge to the car, width wise? My 19x11 ET 51's are flush to the rear fender.
