Headlights - Heat Vision Damage
Old Aug 17, 2014 | 09:03 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Unhappy Headlights - Heat Vision Damage
I have an '07 C4S and I always have the clouding inside the headlights (cover). The clouding shape mimics headlights-bulb burn.
Anyone has/had this issue also?
I understand there's a thread on how to disassemble your headlights. Before I undertake this project, I thought I would ask if anyone had it fixed.
Thanks.
Old Aug 18, 2014 | 05:46 AM
jhbrennan's Avatar
Thanks.
Does it have a non-OEM, higher wattage bulb? If that's what's causing the damage I'd also be worried about the effect of the heat on the connectors. I've never seen heat damage on the inside. From what I understand, they can be repaired but it's a pretty extensive process to separate the lens cover. Are you sure it's on the inside - lots of folks report exterior clouding and that can be polished out pretty easily. Good luck,
Old Aug 18, 2014 | 07:48 AM
soccerTOOLsu's Avatar
soccerTOOLsu is infamous around these parts
I have the same thing on my headlights. '07 Targa 4S
Old Aug 18, 2014 | 08:05 AM
cab83_750's Avatar
Bought the car CPO with 12k miles from dealer. Most likely regular bulbs.
(I don't know the difference).
Definitely inside. This is not your regular clouding/hazing. You can tell it's from the light rays.
PV=nRT.
Sep 9, 2022 06:06 PM
Feelgood MD
Mar 24, 2016 09:35 AM
XLR82XS
Oct 5, 2015 07:02 AM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
