Help with Aero front bar
Old Sep 10, 2014 | 06:25 PM
MYF1's Avatar
MYF1 is just really niceMYF1 is just really niceMYF1 is just really niceMYF1 is just really niceMYF1 is just really nice
I need to replace the standard front bar of my 2006 Carrera S and was looking at replacing it with the Aero Bar.
I am in the process of ordering the bar, the lower lip and both LH and RH retaining frames.
What else do I need to order? Will the existing ducting fit the retaining frames? Do I need the centre section block out piece? Do I need the underside skid plate, any brackets, hardware, etc?
Would appreciate any advice from those who have done this before.
Old Sep 11, 2014 | 05:23 AM
FlaHeel's Avatar
I'm not sure of the "bar" you are referring to but there is an extensive DIY section you should check out if you haven't already.
Old Sep 11, 2014 | 07:02 AM
MarcoRemius's Avatar
MarcoRemius is infamous around these parts
Does Bar=Bumper down unda?
Old Sep 11, 2014 | 07:15 PM
MYF1's Avatar
Yes, sorry. Bar = Bumper, as in bumper bar.
Love the spelling for under btw, spot on for pronunciation.
Old Sep 12, 2014 | 10:10 AM
Phil_D's Avatar
Phil_D is infamous around these partsPhil_D is infamous around these parts
I ordered my Aerokit bumper from Suncoast and it came with everything needed. I assume all the factory ones do. I reused the center section from my OEM bumper and the Aerokit came with the correct ducts for the sides.
Old Sep 12, 2014 | 09:37 PM
MYF1's Avatar
Thanks for your reply.
My preference was to get the bumper from Suncoast but the shipping worked out to be greater than the part, so I am talking to Teile.com. Their parts seem to be all separate units that is why I asked.
Thanks for clarifying the centre section query. I assume it bolts right up if you were able to do this.
Old Sep 15, 2014 | 08:33 AM
Phil_D's Avatar
Yes, center section is a perfect fit, only the side ducts need to be changed.
Enemy
Nov 10, 2015 08:01 AM
orbelo
Aug 30, 2015 12:26 PM
The Oss
Aug 24, 2015 08:19 PM
TrackOne
Aug 20, 2015 12:56 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
