Torque for Magnetic Drain Plug (engine oil)
Old Sep 22, 2014 | 01:48 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Originally Posted by Alexandriusv
It was really clear, it said "19 lbs ft." I was really confused because I figured it could handle at least 37 lb ft since that is stock and its supposedly more durable than the stock one from the description. Alas, that is what i get for thinking.
Metallurgy, I believe, dictates the engineering of any items. As soon as I opened mine and that sticker is as big as the unit itself, I knew it was an impt item to worry about.
Now for us with three, let's hope our Indies and mechanics are aware of the correct torque. I'm not worried since I service my own car.
Old Sep 22, 2014 | 02:41 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
I doubt most indy s and tech s even use a torgue wrench for this.
I just snug mine down. The only thing I used a torque wrench for was spark plugs just because I never did them on this car before.
To answer the OP s second question, a pipe plumbers wrench will grab onto the overhang (which hangs down) from the drain plug. The wrench will sit horizontal and probably flat against the oil pan. (if that makes sense). A small wrench will probably work best. Shouldn t be a problem.
Old Sep 22, 2014 | 02:55 PM
cab83_750's Avatar
Originally Posted by cerbomark
I doubt most indy s and tech s even use a torgue wrench for this...
And that's precisely why 90% of those oil plugs are almost rounded on vehicles that I serviced.
Fyi, I use a torque wrench on almost everything. If the manual states it, then I use it. Heck, 50% of my car work is researching torque values.
Old Sep 22, 2014 | 05:48 PM
Alexandriusv's Avatar
Alexandriusv is infamous around these parts
haha yes I learned a valuable lesson. ALWAYS go with gut instinct when you see a damn label!!!!
But on another note, I'm liking the penzoil 5w40 im running now. Everything appears fine about 500 miles later
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
Lucid Moment
Aug 20, 2015 02:22 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
