Alternator Cable Problem?
Old Jan 8, 2015 | 01:36 PM
sameerg's Avatar
sameerg is a splendid one to beholdsameerg is a splendid one to beholdsameerg is a splendid one to beholdsameerg is a splendid one to beholdsameerg is a splendid one to beholdsameerg is a splendid one to beholdsameerg is a splendid one to behold
I had a harness replaced last week.
My 06 C2S would start fine when cold. After a short drive, lets say, if i were to stop and get gas, it would terrify me that it would not start. Basically, when warmed up or hot, the car would crank slow or just crank and then fail to start until cool.
changing the harness has made an immense difference. Let's see if the problem persists after a few months or not?
Old Jan 8, 2015 | 06:02 PM
lowbee's Avatar
lowbee is infamous around these parts
Good to know, part number please.
How much does changing the harness cost ?
Old Jan 8, 2015 | 07:04 PM
Don's Avatar
Don
Don is a name known to allDon is a name known to allDon is a name known to allDon is a name known to allDon is a name known to allDon is a name known to all
Heck, Suncoast actually has the troubleshooting procedure right in the description of the cable. That is awesome.
Going to see if my shop can do this tomorrow.
http://www.suncoastparts.com/product...ra_S_Engineexl
Old Jan 8, 2015 | 08:59 PM
the997dude's Avatar
the997dude is infamous around these parts
Goodluck Don, hopefully it will work. Let us know!
Old Jan 12, 2015 | 05:39 PM
sameerg's Avatar
Part no. 997 607 019 03
Total cost 750.00
132 dollar part
600 $ labor
Old Jan 12, 2015 | 06:15 PM
yvesvidal's Avatar
yvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of light
In addition to the Alternator cable being replaced, I also attempted to change the starter over the Holidays. The job is much easier than the cable replacement and the starter can be obtained from O'Reilly for $140.00. The starter is made by Bosch and is almost identical to the original Porsche part.
The most difficult part of this job is to re-assemble the resonator and admission hose between the two banks of the engine. There is an excellent DIY at http://rennlist.com/forums/997-forum...l#post11514446. I followed pretty much the explanations with one difference: I removed the serpentine belt and moved slightly the alternator to pass the E-14 socket and extensions required to undo the starter.
After putting everything back together, the car cranks with a lot more gusto at cold. When hot, the starter no longer sounds like an asthmatic patient which is always embarrassing for the Porsche driver....
A cheap and very efficient modifications for 2006 owners.
Yves
jaehoppa
Oct 22, 2015 09:17 PM
LTCJMRamos
Merchandise For Sale / Wanted
Sep 22, 2015 11:16 AM
arhim22
Sep 7, 2015 08:49 PM
