Motorsports Cup Air -AOS- Oil Separator
Old Mar 2, 2015 | 08:03 PM
ehoffarch's Avatar
ehoffarch is infamous around these parts
I am getting ready to have the clutch replaced, 87k, and would like to do the AOS at the same time. Has anyone installed the Motorsports Cup Air -AOS- Oil Separator that is sold by Suncoast in a 997.1 3.8 motor. Are modifications required for the installation. I track the car and this is a modification I see recommended.
Old Mar 2, 2015 | 11:59 PM
PatrickBateman's Avatar
PatrickBateman is infamous around these parts
Go over to pelican... iirc, they have some long winded schpeal on that unit versus the stocker unit.
Old Mar 3, 2015 | 08:01 AM
ehoffarch's Avatar
Patrick thanks for the reply.
I read the article at Pelican and if it is the one you are referring to, it talks about how to replace the oem aos but nothing about the motorsports version. I have done searches on most of the forums and have not had much luck on this subject.
Old Mar 3, 2015 | 10:16 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
I searched Pelican, planet 9, rennlist, etc when I was considering the upgrade. Yes, there isn't one specific to the 997. I am not tracking my car and based on numerous feedback and taking into account the high price of the upgrade relative to the base AOS, I decided to not install it.
I bet the retrofit mods wouldn't be too much involved - but then again, ez and hard ratings are subjective.
GL and keep us posted.
Old Mar 4, 2015 | 09:29 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
well at least they say "modifications may be required to fit some models" as i was pretty sure the MoSport version doesn't (out-of-the-box) fit the S. i have heard from an indy or 2 that it's possible to modify/install in an S but not easy or preferable. Would be nice to hear otherwise as i would also be interested since i track.
good luck
Jul 29, 2019 11:13 AM
nlakind
Nov 6, 2015 10:15 AM
RallyBird
Oct 7, 2015 01:20 PM
orbelo
Aug 30, 2015 12:26 PM
The Oss
Aug 24, 2015 08:19 PM
