Weird ignition/key issue
Old Apr 3, 2015 | 11:16 AM
ACRB's Avatar
ACRB is infamous around these parts
Last night after I parked my car, it turned the car off and went into the house. Absentmindedly leaving the key in the ignition. This morning I went outside and realized the rear spoiler was up. I then sat behind the driver’s seat, saw the keys, tried to remove them, and they will not come out of the lock. The car won’t turn on, and the only instrument light on is the red airbag light.
Any suggestions for this weird one would be greatly appreciated!
Old Apr 3, 2015 | 11:28 AM
ACRB's Avatar
after using the website search feature, I realize it is a truly dead battery.
Old Apr 3, 2015 | 11:49 AM
barncobob's Avatar
barncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the rough
if the battery is 3 yrs + id just go to walmart and get a new one
Old Apr 3, 2015 | 05:08 PM
jhbrennan's Avatar
Did you get the hood open yet so you can swap out the battery?
Old Apr 3, 2015 | 07:00 PM
ACRB's Avatar
Nope, not yet. I thought I would call the Auto Club in the morning and have them open the hood with the instructions in the manual. Then I thought I could get a jump start from them and leave the car running for 30 minutes or so with the hope that the battery will be charged.. Or do you think at this stage it's better just to put in a new battery once they arrive? This one has been fine, but it is over 3 years old. Also, will the air bag light automatically go off once its charged, or is that a dealer reset?
Old Apr 4, 2015 | 06:02 AM
barncobob's Avatar
is it possible to charge battery through cigarette lighter with trickle charge
Old Apr 4, 2015 | 06:06 AM
jhbrennan's Avatar
Sure...but the likelihood of reviving a dead battery this way is pretty slim.
Old Apr 4, 2015 | 05:26 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
I wouldn't recommend charging the battery by running the car. The alternator was never meant for this hard task. Charging a dead battery this way often results to a shirt-lived alternator--but that's me.
If I were far away from home and couldn't wait for a truck, I would. But since the car is in the garage, why take chances killing the alternator.
Old Apr 4, 2015 | 09:36 PM
ACRB's Avatar
i took your advice. The AAA kid came over jump started the car, and I then took it out for a spirited drive. By the time I was at the end of the driveway all warning lights were off, and the battery seems fine by the time I returned home 30 minutes later. What was weird was the spoiler going up when the battery initially died, almost like a warning flag that something was wrong.
Old Apr 4, 2015 | 11:35 PM
PatrickBateman's Avatar
PatrickBateman is infamous around these parts
regardless of what batteries say....72,84 month warranty, etc... im with the majority here by thinking a new battery should be installed in quick order.
I don't want to rely on a battery I know has been drained and dead at some point.
And yes, the walmart batteries are very good quality.
Old Apr 5, 2015 | 06:45 AM
jhbrennan's Avatar
Glad you got it sorted...but replace your battery. Once a battery starts showing "dying" signs, they can go from good to bad overnight - you don't want to get stranded when a new battery can reduce that anxiety.
Old Apr 5, 2015 | 09:54 AM
barncobob's Avatar
U don't need new battery, u have AAA, make sure its paid up and current
Old Apr 5, 2015 | 10:01 AM
cab83_750's Avatar
. Note that AAA will cancel your membership if usage becomes too much.
Old Apr 5, 2015 | 10:18 AM
cab83_750's Avatar
... Or ensure you're healthy and learn how to push the car and pop the clutch.
Old Apr 5, 2015 | 11:32 AM
barncobob's Avatar
if u have an automatic take your running shoes with you
