IPD Plenum GT3 Plenum & Throttle Body
Old Jun 2, 2015 | 07:46 PM
Gary B's Avatar
Gary B has a spectacular aura aboutGary B has a spectacular aura about
Bolt on power in an hour
Added drop in a BMC air filter, and WOW... Next step EVOM ECU tune and I'll be set.
Old Jun 2, 2015 | 07:59 PM
MYC2SPC's Avatar
MYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really nice
I have all of the above from IPD and the FabSpeed CAI. in red, along with the BMC Filter.
Old Jun 2, 2015 | 09:23 PM
PatrickBateman's Avatar
PatrickBateman is infamous around these parts
Am I the only one who is just underwhelmed by N/A motor bolt on mods? It seems to offer a bit of punch at 5000 rpm and up, but like others have claimed, low end grunt is lessened by this mod.
Old Jun 2, 2015 | 09:27 PM
malahhaor's Avatar
malahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to behold
I got the GT3 TB with Softronic Plenum and EvoM intake box.
The car did not run very smooth in temp below 50. I would constantly get CEL errors on MAF. Yes i checked voltage with Duramatic, MAF seemed fine. I guess too much air is moving outside of Porsche programmed range.
The intake did make a tiny difference above 3K, but no difference when added the TB and Plenum to it.
I ordered a Softronic tune, hopefully i'll get it installed this week.
Keeping fingers crossed it will make a difference.
Old Jun 2, 2015 | 09:31 PM
malahhaor's Avatar
need to get more exhaust moving out if youre getting more air moving in. Then need to tell ecu how to use it better with a tune. But thats just my opinion.
Otherwise it will not do as much as everyone hopes.
Old Jun 4, 2015 | 04:23 AM
mk3boy's Avatar
mk3boy is just really nicemk3boy is just really nicemk3boy is just really nicemk3boy is just really nice
I'm debating evoms tune or dyno tune. what do you recomend? I have all the bolt ons include headers
Old Jun 4, 2015 | 06:12 AM
Don's Avatar
Don
Don is a name known to allDon is a name known to allDon is a name known to allDon is a name known to allDon is a name known to allDon is a name known to all
Did you have challenges with IPD's silicone tube? I had a difficult time fitting it.
Old Jun 4, 2015 | 06:58 AM
mk3boy's Avatar
yes it was challenging to figure out if it was on right. Had to turn tb on a angle also. This along with rss engine mounts, numeric cables and evoms intake...
Old Jun 4, 2015 | 07:24 AM
Gary B's Avatar
Don - I gave each side a shot of silicon spray, they went on in less than five minutes. The entire project took less than an hour start to finish. There is a noticeable increase in power between 4,200 and 6,500 RPMs. I have to tweak the tune to fill in the gap on the low end power. I should have don this a longtime ago.
Old Jun 4, 2015 | 07:31 AM
Don's Avatar
Don
When I did mine it seemed like the hose they provided was nearly a 1/2" too long.
Old Jun 4, 2015 | 07:32 AM
mk3boy's Avatar
what tune you running Gary?
Old Jun 4, 2015 | 07:36 AM
Gary B's Avatar
EVOM - it's going to be done later this month, put in and Dyno at Porsche dealership here in Tampa. They have a speed shop that host cars and coffee events. They run a race team and host PCA events at Sebring several times a year. They are good people.
Old Jun 4, 2015 | 09:23 AM
Don's Avatar
Don
That is awesome.
Old Jun 4, 2015 | 10:14 AM
mk3boy's Avatar
do you need the evoms chip even if you will dyno?
Old Jun 4, 2015 | 10:30 AM
CoreyC2S's Avatar
CoreyC2S is just really niceCoreyC2S is just really niceCoreyC2S is just really niceCoreyC2S is just really niceCoreyC2S is just really nice
There's not a lot you can gain from an N/A engine with bolt-ons, generally speaking, unless the manufacturer really cheaped out on a particular component and left power on the table.
Does anyone offer an intake manifold spacer? I've noticed a few cars can benefit from spacing the manifold a bit; not sure if it would even fit in this application or if it would gain anything, but thought I'd ask...
