Wheel Bearing Install Issue :help:
Old Jan 9, 2016 | 08:28 PM
NYC997's Avatar
NYC997 has a spectacular aura aboutNYC997 has a spectacular aura about
Install Issue
Install Issue
Old Jan 10, 2016 | 09:27 AM
slammp's Avatar
slammp is infamous around these parts
I would hand sand it down just to be careful. A Dremel may take too much material too quickly.
Old Jan 10, 2016 | 10:51 AM
Macster's Avatar
A problem with sanding is you while you remove the ridge you can also remove material from around the ridge, over a wider area, and this can (could) have the bearing fit a bit loose.
Since the ridge is a very localized anomaly I would take a scraper knife and just scrape away the ridge. While you will probably remove more material than the ridge you do so in a very small area -- compared to sanding -- and this does not effect the bearing fit.
You want to use a good straight edge and a bright light to ensure you have removed all the ridge so the bearing when pressed in doesn't encounter any ridge remnant. If it does it can result in a bearing fit that is not quite square with the bore of the bearing housing and can lead to premature failure of the repalcement bearing.
PrMike
Feb 12, 2016 11:32 AM
mateush
Dec 30, 2015 04:29 PM
Southpaw07
Dec 16, 2015 06:02 PM
boochook
Cayenne 958
Dec 14, 2015 04:38 PM
PrMike
Dec 9, 2015 02:06 AM
