Shifter cable replacement
Old Mar 14, 2016 | 10:57 AM
scottmc's Avatar
scottmc has a spectacular aura aboutscottmc has a spectacular aura aboutscottmc has a spectacular aura about
My shifter cable decided to break over the weekend and needs to be replaced. Actually, it didn't break; one of the rod ends on the gearbox side is worn out and popped of the ball end. Anyway, does anyone have advise on how to get the rubber grommet under the hand brake out and back in again. Mine seems to be welded/gorilla glued in. Thanks...
Old Mar 14, 2016 | 09:27 PM
caslca's Avatar
caslca is infamous around these partscaslca is infamous around these parts
I pushed mine from the inside of the car. I used a hammer flipped backwards and used the hammer handle to push the rubber out. It did take a lot of effort to do so, but just wait till you try to put it back in
Do you have C2 or C4? The AWD prop shaft will be in the way if you have a C4 and I would strongly recommend you remove it to push the rubber piece back in.
Old Mar 15, 2016 | 11:16 AM
scottmc's Avatar
Thanks! I'm going to attack it this weekend. I'll let you know if I (and the car) survive...
Old Mar 15, 2016 | 12:51 PM
caslca's Avatar
BTW, get a silicone spray and spray liberally all around the rubber and also along the 3 cables that go through it. Same for the installation.
vman932
Jun 14, 2016 06:34 AM
o'bluetouring
Jun 9, 2016 09:32 PM
Redmonkey928
Apr 25, 2016 12:53 PM
vman932
Mar 17, 2016 06:47 AM
uk997ttnut
Mar 9, 2016 08:52 AM
