Heel and toe downshifting
Old Dec 23, 2005 | 07:49 PM
Redlined's Avatar
Redlined has a spectacular aura aboutRedlined has a spectacular aura about
JLEE, just reread your post. With synchromesh trannys you really don't need to double clutch, the car takes care of most of that for the driver in a normal downshift in a street car such as a P car. My understanding is that relatively simple race cars do not have a large synchromesh tranny. Don't mean to sound like Skippy but consider driving at 80 MPH in 4th gear then a quick downshift/abrupt declutching into 2nd. The rear end screams as the drive train can't keep up. The engine over revs as the tires smoke and some component of the drive train fails under pressure. Not a pretty picture.
Old Dec 24, 2005 | 05:07 PM
schicago's Avatar
schicago is infamous around these parts
redline your're right. but even syncros wear and double clutching slows the process.
also, on the track you are either on the gas or on the brake but no coasting.
Old Dec 24, 2005 | 05:20 PM
jlee's Avatar
jlee is just really nicejlee is just really nicejlee is just really nicejlee is just really nice
Now I see the light!
Old Dec 24, 2005 | 07:44 PM
Redlined's Avatar
Yep, synchros wear eventually I'm sure. But if you want to be quick in a modern car one can't even consider double clutching.
Coast??? Why bother tracking the car? Even green run group students realize that rapidly.
Old Dec 24, 2005 | 08:23 PM
PMac's Avatar
PMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to behold
Originally posted by jlee
depress clutch, shift down, keep clutch depressed, and when I am done with the braking, press on the gas to rev match and release clutch
There's your problem. Try doing exactly what your doing, but as soon as you're in the next gear down, and still braking, blip the throttle and release the clutch.
Never be coasting with the engine and wheels disconnected any longer than necessary.
Truthfully, heel-and-toe is a bit awkward on the street unless you're braking quite hard. The brake pedal isn't down far enough to easily get over to the throttle.
On the street, with gentle braking, do your braking first, release the brakes, then clutch in, new gear, blip, clutch out. It's still not ideal, but at least you won't be coasting.
Old Dec 24, 2005 | 08:29 PM
air-cooledjbj's Avatar
air-cooledjbj is infamous around these parts
Old Dec 25, 2005 | 11:30 AM
schicago's Avatar
i have seen an experienced driver turn his engine to mush by screwing up a downshift on the track. The last driver that cooked his engine was two run groups above novice.
i would not wish that outcome on anyone whether a juvenile driver or not.
I do wish all 6speeders a happy and healthy holiday season.
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
007 Vantage
Oct 8, 2015 08:35 PM
dynamic gt2
Sep 28, 2015 03:40 PM
