Lights in the Passenger Side Door Not Working.
Old Mar 7, 2017 | 08:47 PM
Grey Goose's Avatar
Grey Goose is infamous around these parts
I have a strange issue that I've just noticed. None of the lights on the passenger side door are working. My courtesy light, door sill light and window switch illumination (supposed to come on when headlights are switched on) are not working on my passenger side door.
The window works as normal and the footwell light works...but not the courtesy light, door sill light and window switch light.
I checked all the fuses in the footwell panel of the driver's side and they all look good. I'm completely baffled...any suggestions?
Thanks in advance
Old Mar 8, 2017 | 06:32 PM
MYC2SPC's Avatar
MYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really nice
First off...what year is this?
Old Mar 8, 2017 | 06:34 PM
MYC2SPC's Avatar
Have you toggled the overhead middle switch?
Old Mar 8, 2017 | 06:37 PM
MYC2SPC's Avatar
I have illuminated LED door sill lights. Not standard on a 997.1 If the center rocker switch on the overhead is not in the middle it will affect your sills and your foot well lights but your door courtesy lights should still stay on?
Old Mar 8, 2017 | 10:34 PM
Grey Goose's Avatar
2011
Yeah, I've tried all 3 positions..the driver side door sill light comes on but not the passenger side. I'm thinking all the lights in the passenger door are somehow linked?
Is there a relay or something that controls all the lights in the door?
I've checked all the fuses in the driver side footwell and they all looked good.
Old Mar 9, 2017 | 11:39 AM
Kellen's Avatar
Kellen has much to be proud ofKellen has much to be proud ofKellen has much to be proud ofKellen has much to be proud ofKellen has much to be proud ofKellen has much to be proud ofKellen has much to be proud ofKellen has much to be proud of
Are they LED? I bought LEDs from sun coast and the bulbs fall out needing to be put back in. I would start by making sure the bulbs are seated well.
Old Mar 9, 2017 | 02:18 PM
MYC2SPC's Avatar
It's probably because it's a 997.2 and totally different from the 997.1? I haven't had an issue at all with my LEDS throughout mine? Hopefully someone will chime in soon to help? Good luck!
Old Mar 9, 2017 | 08:25 PM
Grey Goose's Avatar
Stock bulbs...door sill light looks to be LED (white light) and the courtesy light and window switch illumination are non-led.
997.1 and 997.2 appear to be the same...I had a .1 prior to a .2. I'm thinking it's something these 3 lights are connected to? I'm completely baffled and it's rare that search doesn't yield anybody else ever having the same issue
