greasy front rim
Old Mar 16, 2017 | 07:32 PM
pak6698's Avatar
pak6698 is infamous around these parts
greasy front rim
Can anyone help out please.
I wash washing my car today and noticed some grease on my wash brush after washing the passenger side front wheel of my '08 c4s cab. I use a very soft bristle brush for the rims only. The bristles are less than 1" in size. While washing behind the front of the rim I brought out the brush to get more soap on it and discovered it was covered in grease.
What would this mean.
I know I have to take it in for this but I would like to know what I'm looking at.
Thanks for any help.
Old Mar 16, 2017 | 07:36 PM
JackZ R's Avatar
JackZ R is infamous around these parts
Brakes OK? Could even be a glob of truck grease you picked up when driving.
Old Mar 16, 2017 | 07:43 PM
pak6698's Avatar
Brakes are fine, just done about 5k ago.
Hope you are right about just a blob.
I will still make an appointment just to satisfy myself.
Old Mar 16, 2017 | 08:57 PM
Jeller's Avatar
Jeller is infamous around these parts
Tear or hole in the CV boot? since you are a 4S
Old Mar 16, 2017 | 09:04 PM
pak6698's Avatar
thanks Jeller
Is that a costly repair
Old Mar 17, 2017 | 07:41 AM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
Jack up the corner, remove the wheel, and visually inspect. In the wheel well you have ball joints on the control arms, CV joint to the axle, wheel hub, brake lines, shocks, lower control arm hydraulic bushing, and steering linkages. Most use grease, others use fluid that can be confused with grease if it leaks and mixes with dirt or brake dust.
Take a picture of anything you see that looks like a problem and post it here.
Old May 12, 2017 | 02:20 PM
Weasel's Avatar
Weasel is just really niceWeasel is just really niceWeasel is just really niceWeasel is just really niceWeasel is just really nice
I experienced this with my 2006 C4S recently. Strangest thing. Ruined my wash mitt. Before I go taking things apart/off, has anyone figured out the origin?
Old May 12, 2017 | 04:56 PM
pak6698's Avatar
mine ended up being a CV Boot. I noticed this grease on the inside of my front passenger rim. Once at the shop, it was discovered the drivers side had a small tear in the CV Boot as well. It was a no brainer to have both sides, both the inner and outer boots replaced on both sides. Even though the inner boots on booth sides were still good, the cost difference made it an easy decision to have booth ends replaced since the axle was already out. Expensive yes, but now its done.
Old May 19, 2017 | 12:58 PM
toptier's Avatar
toptier is infamous around these partstoptier is infamous around these parts
Most likely a torn CV boot. Mine went around 50k miles.
