Oil Leak on engine mount
Old Nov 2, 2018 | 06:37 PM
lewissimo's Avatar
lewissimo is infamous around these parts
I just changed the rear engine mounts on my 997.1
After a short run, I noticed oil dripping underneath. It appeared to be coming from beside the right side engine mount. Removing the air-box I saw this. Oil around the top indent of the motor mount, overflowing and dripping down to the garage floor. A drip every 5 seconds with the motor running. Where could it be coming from?
There is no other oil on ANYTHING that I can see or feel.
(Does the motor start without the air-box plugged in and attached?)
Rob
Old Nov 3, 2018 | 11:21 AM
Jeller's Avatar
Jeller is infamous around these parts
Most OEM mounts are liquid filled. Sounds like you have a leak...
Old Nov 3, 2018 | 06:09 PM
lewissimo's Avatar
That would explain it alright. I will put the old one back in and go for a short drive and see if there is any oil leak.
I bought them from Pelican Parts and if I phone them up and tell them about it, that would be proof positive of a defective part.
If that's what it is. Re 'n re an engine mount takes less than an hour once you've done it already.
Old Nov 5, 2018 | 10:11 AM
lewissimo's Avatar
So I did put the old one back in and no oil. The new mount definitely weeped oil out of the top crimp when I held it sideways.
Phoned Pelican Parts this morning and they will send a new part, as I fully expected they would.
Rob
Old Nov 6, 2018 | 02:02 PM
Jeller's Avatar
**** happens, at least its an easy fix.
Dale D
Cayenne 955/957
19
Aug 12, 2018 06:45 AM
newporsche
Jun 29, 2018 03:46 PM
///amgny
Dec 30, 2011 11:47 AM
bond
Jan 31, 2006 11:07 AM
