Window auto-drop won't stay down
Old Apr 3, 2020 | 09:14 PM
ArancioBorealis's Avatar
Registered PM
ArancioBorealis is infamous around these parts
When I open the passenger door by slightly pulling the exterior handle everything works fine, meaning that the window goes down and stays down until I close the door.
The problem only occurs if someone pulls the exterior handle all the way to the end of its travel.
In that scenario the window goes down but goes up again as soon as you leave the door handle to get inside the car and therefore the window hit the door surround...
Old Apr 4, 2020 | 08:19 PM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
There are 4 micro-switches that control the window drop and raise functions. Once the window drops from the exterior door handle microswitch (which sounds like it's working), the one in the latch mechanism keeps it down until the door is shut and then that switch closing let's it go back up. Sounds like it's that one that has gone bad.
Old Apr 21, 2020 | 04:48 PM
Nacsa's Avatar
Registered PM
Nacsa is infamous around these parts
When you open the door, does the window rise again?
The same thing happened to me in one of the 997 I had, it is the microswitch of the door lock. Although you can change the microswitch only, the lock is cheap, since it is the same part number as the lock on a Golf V for example, it is directly a Volkswagen part number.
Old Apr 27, 2020 | 06:20 PM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
How old is your battery? the windows have been known to get a little buggy with old batteries. Sometimes they need to be reprogrammed. I think there's some procedure in the manual.
Reborn996
Aug 31, 2014 01:20 PM
faandba
Jul 13, 2013 01:04 AM
alex55
Mar 28, 2012 11:00 AM
drhenrock
Apr 28, 2010 08:25 AM
Terminator
Mar 31, 2009 11:53 PM
