Radiator and engine compartment fans coming on and staying on, when cold
Old Mar 23, 2023 | 10:44 AM
jchapura's Avatar
jchapura has a spectacular aura aboutjchapura has a spectacular aura about
My 2005 C2S 997.1 has been sitting for a few months. It has been on a CTEK battery maintainer. I took it out for a one hour drive today. Just after engine startup, at the end of the drive, and another engine startup after a two hour rest in the garage (water temp gage showing about 120degF), it exhibited symptoms I'd not seen before.
Immediately at startup with a cold engine, the engine compartment fan came on and stayed on.
About 30 seconds after engine startup, both cold engine and warm engine, both radiator fans came on and stayed on.
I have a Durametric and captured the following fault codes while the engine was running (I traversed every menu item on the left of app window):
C140
C141
C131
C152 (I think this is due to the inactivation and removal of the PASM module when I converted to coilovers)
8004
8028
8029
8042
FWIW, I was not in ECO mode so the air conditioner compressor was probably running. I was trying to recirculate the freon and oil. (I usually run in ECO mode.)
FWIW, there's no CEL indicator showing on the instrument display.
Engine water temp about 105degF.
Started engine.
Engine compartment fan is on.
Within 30 seconds both radiator fans roaring (seemingly like they are on high).
Using Durametric, went to Front/Activations and found 3 "Radiator fans" (not sure why there's 3). See pic below.
First entry - clicked STOP. Nothing happened.
Second entry - clicked STOP. Nothing happened.
Third entry - clicked STOP. Nothing happened.
First entry - clicked START. One of the front fans (or maybe both, it got quiet) slowly spun down and then 10 seconds later it went back to high.
Second entry - clicked START. One of the front fans (or maybe both, it got quiet) slowly spun down and then 10 seconds later it went back to high.
Third entry - clicked START. Nothing happened.
Toggling the ECO button on the climate control didn't seem to make any difference.
Gas has Stabil in it.
Battery's installation date is July 2014.
Yesterday, after the battery-maintained multi-month inactivity, the car acted OK - normal starter rotation speed and fire-up time.
Today, battery's voltage after sitting all night, NOT on the battery maintainer, is 12.67v.
Why might these fans be acting abnormally?
scottydog
Nov 11, 2024 05:50 PM
150shot
Mar 8, 2015 12:48 PM
hamlmarzooqi
Jun 24, 2013 07:43 PM
JoelPirela
Jul 1, 2008 01:20 PM
kayman
Jun 5, 2007 06:07 PM
