engine blower fan
Old May 2, 2007 | 03:52 PM
kayman's Avatar
kayman is infamous around these parts
engine blower fan
I've noticed that now that the weather is warmer, the engine compartment blower fan always turns on after shutdown. Even after short drives it comes on and stays on for a good 5 minutes or so. Is this normal? Just got the car couple months ago so I'm not familiar with the fan's normal behavior.
Old May 2, 2007 | 04:01 PM
sand bandit's Avatar
sand bandit is infamous around these parts
I've only had my car for a few months also and noticed the same thing. It's heating up here in AZ and I notice that the fan comes on after shutdown just about any time I drive it.
Old May 2, 2007 | 04:07 PM
slant911's Avatar
slant911 is infamous around these parts
Mine too. I've been told it's normal. Fan comes on to cool off the engine bay based on some temp threshold. This "system" stays active monitoring that temp for something like 20 minutes after parking and cycles the fan as needed.
Old May 2, 2007 | 04:23 PM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
Yep, once it gets hotter out, it will turn on for a few minutes. My car sometimes stays on for 5 or more minutes then stops...then turns on again sometimes when it is really hot out.
Old May 2, 2007 | 04:32 PM
atlshaver's Avatar
atlshaver has a spectacular aura aboutatlshaver has a spectacular aura about
It will continue to run (turn on and off) until a preset underhood temp is reached. Can't remember the temp but I am sure someone will chime in with that piece in info.
Old May 2, 2007 | 05:29 PM
acf's Avatar
acf
acf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to behold
Yet we still need to idle for 1-2 minutes to cool down the engines in addition to the fan..
Old May 2, 2007 | 05:41 PM
wross996TT's Avatar
First the fan does go on when a certain temperature is reached...even after shutdown (it may cycle on and off multiple times).
Second, you idle your car for 90-120 seconds to cool the turbos, not the engine. The main source of cooling for the turbos is oil. Once you shut the car off the oil stops circulating. Next time put your hand on one of the turbos after you stop (just kidding). They are extremely hot...the circulating oil helps them cool.
Old Jun 5, 2007 | 04:44 PM
kayman's Avatar
I've noticed that sometimes the fan stays on for 15-20 min consistently. Please tell me this is normal!
Old Jun 5, 2007 | 06:07 PM
quicksilver01's Avatar
quicksilver01 is infamous around these parts
I have the opposite situation. I've had my 01 TT with 30,500 miles for over a year. The fan has not come on ONCE after shut down since I've owned the car. I brought the car to my dealer who insisted it checked out perfectly and that there was nothing wrong. I have several buddys who have turbos and it baffles me that after a spirited ride, when we shut down, their fans come on and mine doesn't. My dealer told me to "drive it harder". Now, I am CPO'd for several more months. Why wouldn't my dealer swap out my fan something wasn't right? My garage heats up at leat 10-15 degrees after I pull in and shut down. Any thoughts?
Jul 29, 2019 11:13 AM
nlakind
Nov 6, 2015 10:15 AM
turbotuner20v
Sep 11, 2015 12:02 PM
cinellipro
Aug 30, 2015 03:48 PM
LiquidElephant
Aug 27, 2015 06:17 PM
