Help- Accelerator Potentiometer replacement- X59 plug location engine bay
Old Nov 20, 2024 | 08:06 AM
GCB's Avatar
GCB
GCB is infamous around these parts
Can anyone help answer any of these questions please:
1. "How to" instructions for replacing Accelerator Pedal Potentiometer ?
2. Where are the x59 1/2 connectors located In the engine bay?
3. And even better... which pins run to the Accelerator Pedal Potentiometer?
Old Nov 21, 2024 | 09:07 AM
964hans's Avatar
964hans is infamous around these parts
Maybe this helps
Regards
Hans
File Type: pdf
Old Nov 21, 2024 | 10:41 AM
GCB's Avatar
GCB
Originally Posted by 964hans
Maybe this helps
Regards
Hans
Thank you so much! This shows the plugs in passenger compartment?
Do you know where in the compartment?
I was told they were in the engine bay area?
Old Nov 21, 2024 | 12:26 PM
964hans's Avatar
The plugs TSX59_1 en TSX59_2 are in the engine bay, that's correct. The accelerator pedal signals are routed to the DME via plug TSX2_3
Old Nov 21, 2024 | 03:23 PM
GCB's Avatar
GCB
THIS IS GREAT!!!!
Thank you 964hans ... much appreciated!!!!
LouDA
Jun 7, 2020 09:29 AM
pacastro
Dec 12, 2013 10:49 AM
white out
Nov 22, 2012 11:14 AM
TXGold
Apr 18, 2009 11:30 PM
gneypiks
Jun 12, 2004 06:58 AM
