Garage door opener help
Old Aug 6, 2013 | 11:17 AM
  #31
Romysc4s's Avatar
Romysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud of
No need to turn engine on.
Old Aug 6, 2013 | 03:07 PM
  #32
OldBoldPilot's Avatar
OldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond repute
Thanks for the tips, guys, but it still didn't work. I'll let the dealer figure it out; it's on CPO.
Old Aug 7, 2013 | 05:42 PM
  #33
Jonny911S's Avatar
Jonny911S is infamous around these parts
Thanks for this, I just got it working!! I'd given up a while back, just figured my model wasn't compatible. Once I hit the program button on the unit itself it worked.
Old Jan 19, 2014 | 11:42 AM
  #34
keng1's Avatar
keng1 is infamous around these parts
Thanks for all your suggestions...i could not get it to work with the instructions in the manual until I read this post. The key is where you put your garage remote against the car remote.
I pressed the button on the hand held remote and held it against the center console light. Simultaneously pressed the button on the car garage opener and it took the code almost immediately (5 secs) and I got the fast flash. After, I just pressed the learn button on the opener itself and then held the car remote button. Garage light flashed. And there is peace in the household again.
Old Jan 21, 2014 | 11:21 AM
  #35
Mr. Meister's Avatar
Mr. Meister is infamous around these parts
So many attempts, so may failures. ugh.
Old Jan 21, 2014 | 03:16 PM
  #36
myw's Avatar
myw
myw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to behold
are you able to get your 911 homelink to successfully learn the signals of the car itself? (ie. get the fogs to flash 3 times?)
Old Jan 21, 2014 | 05:30 PM
  #37
That's where I got stuck. Two different dealers' service departments couldn't manage to do it, either. They surmise that the unit inside the bumper is either damaged or disconnected. I'll let them delve into it next time my car has to be at the dealer (which I try to avoid as much as possible) for some other CPO-covered item. Meanwhile I'm using a keychain remote, which is just as convenient and possibly more secure.
twnj
Apr 29, 2016 05:18 AM
RallyBird
Oct 7, 2015 01:20 PM
pshep138
Sep 1, 2015 09:45 AM
I'mAllIn
Aug 25, 2015 09:44 AM
Glasig
Aug 23, 2015 03:35 PM
