need help understanding mt dyno sheet
hi all,just had my car dyno'd..i dont get some of the numbers..the max number do not coincide with the graph...i dont know if this is due the temp around the car or somthing else...the max number look preety good for a 3.6 with miner mods i think..mods are as follows- revo ecu upgrade,agency power muffler and k&n drop in filter..please let me know what the diifernt numbers mean.thanks alot in adavce....
http://www.rennteam.com/showflat.php...gonew=1#UNREAD
this is the link beacause ir wont let post any attachments here on 6speed
i think i figured it out.it looks like the max h.p, numbers are around 7200 rpm..i dont know how usefull that horsepower is way up there...any thoughts please let me know,
Those numbers are actually alittle high for a 3.6 because they are not using a SAE C.F., if you notice on the top right hand corner it shows CF: STD not SAE, if they were SAE you can probably lop off about 10hp. Still your numbers are right where a non S should be if not alittle better.
Dave
Dave
Dave07997S
thanks for the info on sae and non sae . i did not know that.they said the numbers would have been 3 or 4 hp higher ,but it was so hot that they were not.i am thinking about adding headers or a plenum next.not sure which one...any thoughts would be great.thanks again
Didnt read your whole post, didnt see that you had the REVO upgrade and the mufflers. I was going to say you are probably up 10-15rwhp over a non modded non S. Good job...what octane fuel were you running?
Dave
Dave
Originally Posted by carmos
hi dave,i was running 91 octane chevron.so just normal gas...any thoughts on headers or plenum.
This is just my opinion on this matter, so once again your mileage will vary..
Dave
hi dave, i think i am going to go the plenum route,because when i had my boxster s and mod'd it.i had major headaches when i switched the cats..never ending cels and other stuff..my hope is to get 7 or 8 hp from the plenum which would put my max hp t about 297 or 298 hp to the wheels..the place i did my dyno run is the same place that european car mag did theres for the tests on the 997S the modded .they put on a cargraphics system,headers,cats and mufflers..and then the plenum...there base hp for the 997S was 296.so i would like to get somthing around that...will see what happens..thanks again for the help and ideas.
thanks for the info blakt out. do u know if they did sae or standard? the standard runs about 4 % higher than the new sae..the run the guys did at gt pro on there 997s in stock form was in sae.they got 296 hp.if u do the 4% thing .the hp would be 307.84 hp. close to ur hp.thanks for any more info.i am just tring to figure this thing out.i answer one question only to start asking myself 2 more.this hp thing is a pain in the ***
.thanks again
.thanks again
.thanks again
.thanks againDave
hhhmm ok that makes sense.thanks dave
Dave
If you are near Huntington Beach there are several stations including Evosport that carries VP Racing 100, I think Evosport sells it for like $6.99 per gallon.
Here is a list of stations:
Fullerton
Mark's 76
2043 W Commonwealth Ave. (cross of Gilbert)
Between Magnolia and Brookhurst, north of I-5 and 91 Fwy. (714) 278-0986
100 octane unleaded at the pump 06/27/06
Open 24 hours
Huntington Beach
Huntington Beach Car Wash
18971 Beach Blvd near Garfield Ave. (714) 847-4924
Hours: 8 AM - 5 PM, 7 days a week.
100 octane VP Racing at the pump.
Pump is padlocked because that pump doesn't have an ATM reader. You'll need to pay inside. 01/29/07
Laguna Hills
76 Station
25172 Cabot Rd. (near La Paz) (949) 770-8300
100 octane unleaded at the pump (multiple pumps) 10/27/06
Newport Beach
Newport Hills 76
2690 San Miguel Rd. (949) 644-7151
Hours: 6 AM - 10 PM, 7 AM - 10 PM on Sundays.
100 octane unleaded fuel at the pump 01-29-07
Orange
Mitchell's Auto, "The Pit Stop"
700 Chapman Ave. (714) 532-5900
100 octane unleaded at the pump 07/23/07
Hope this helped...Give them a call before you go, as Im sure a few of them may have stopped carrying it.
Dave
Fullerton
Mark's 76
Open 24 hours
Huntington Beach
Laguna Hills
76 Station
Newport Beach
Newport Hills 76
Orange
Dave
