Friend took her Shelby to the track for the first time.
SubscribeIt is all stock except for a Cold air and tune.
http://videos.streetfire.net/video/J...108_201035.htm
Here is her Husband in his 07 GT with a novi 2200 and bolt ons.
http://videos.streetfire.net/video/E...108_201034.htm
Here are the rest of the cars that went to our rental.
http://videos.streetfire.net/video/B...the_201037.htm
http://videos.streetfire.net/video/L...tal_201045.htm
Did you run with DR's ? Good times, hell excellent times. That pig can move when it wants to. Plus 1 to your rep.
Quote:
Are you talking about my run in my sig? cause the Shelby is not mine.Originally Posted by prpsebuilt
Quote:
Yes, I had a KB 2.2 with a Viper spec T-56 and a SRA. I always ran on pump gas and drag radials. I sold the KB and am in the process of building my motor and adding a Hellion TT kit.Originally Posted by revracer
Whats your setup? I think Ive seen you post on SVTP before and its a KB 2.2 car with a built T56 if Im not mistaken. Those cobras sound amazing. Is that GT a built motored car?
Quote:
Fast cars, looks like a fun day.
Yes you did. I'm Tie fitr on there.Originally Posted by JROW
Think I saw this stuff on vadriven?Fast cars, looks like a fun day.
Quote:
yes they can. here is another excellent time on a modified gt500 with stock blower.Originally Posted by prpsebuilt
keep in mind this driver had his out once when it was stock. 2.155 - 12.351 @ 116.287 STOCK
Quote:
Napierville dragway montreal canada oct 19th 2008
1.442 / 6.681 / 103.730 / 10.473 / 131.853 temp 46.4 57%H 30.49BP side/head wind 2.4mph 11.18am
1.457 / 6.702 / 104.183 / 10.498 / 131.200 temp 48.2 46%H 30.44BP
side/headwind 4.2mph 1.32pm
Mods 07 GT500 coupe race weight 3918lbs 8175 miles CFUXSEHGK
Stock clutch/transmission
Stock un-ported blower/TB
2.6 upper
08 GT500 stock lower
JLT CF intake
AR longtubes w/catted X-Pipe and MBRP axelback
Eibach lowering springs
Aluminum driveshaft w/loop
BMR U/L control arms & mount
4.10 gears w/detroit truetrac
Holeshot drag wheels 15x10 rear & 15x4 fronts
Hoosier 27x4.5x15 fronts & 28x10.5x15 rears
6pt NHRA legal roll-bar
Tuned by Jon Lund
40/60 mix of 94 octane pump gas and C16 race fuel
Originally Posted by MD03SVT
Great air great traction = Great TimesNapierville dragway montreal canada oct 19th 2008
2.6 upper
JLT CF intake
Tuned by Jon Lund
Quote:
It's the Hellraiser kit, bit I'm not using the blower. It just gets in the way and hurts power above 4500 rpm.Originally Posted by revracer
Are you doingn the hellion hell raiser kit? I would just go with the HPP kit if it was my car.
I'm friends with a Hellion dealer and got a hell of a deal on it. You also can't beat their on the shelf kits with no waiting and great customer service, along with their quality all stainless kits.
Nice choice on the blower delete. I can respect that theres less lag but at the same time there is more heat and it still has the loss of hp from the blower. Are you gonna run a sullivan intake, 01 style intake, or something different? Stroker motor or stock ci? What turbos? Sorry for all the questions Terminators are up there on my favorite car list.Originally Posted by 2bscrewed
It's the Hellraiser kit, bit I'm not using the blower. It just gets in the way and hurts power above 4500 rpm.I'm friends with a Hellion dealer and got a hell of a deal on it. You also can't beat their on the shelf kits with no waiting and great customer service, along with their quality all stainless kits.
Quote:
No problem, I can't drive the car right now, so i might as well talk about it! hahaOriginally Posted by revracer
I'm using my block bored .020 over, stock crank, Oliver billet rods, Coated JE pistons bringing the compression up to 9.2-1. New Livernois stage II heads with custom turbo grind comp cams. I'm gonna try a Procharger sheet metal intake designed to work with the stock lower. Hopefully the alternator will clear the intake. I'll find out when the top of the motor get together in a week or two. I'm hoping for at least 750whp on pump gas. I will also probably put a meth kit on the car next year to really turn up the boost and see what it will do. I also just got my tranny back from Liberty Gear. They faceplated it, and freshened it up. I'm hoping that will help the shifting out and allow me to stay in boost during the shifts. My tranny would not allow me to power shift in the past. that's why I'm granny shifting in my vid in my sig.
My goal is to run a 9 in full street trim on pump gas.
My friend put this kit on a stock long block car here and it made 698 hp on 15#'s of boost, 13* timing and pump gas, so I'm hoping I get quite a bit more out of my set up. The added compression, ported heads and turbo cams should help my power and spool time considerably.
698 whp out of 15lbs is some good numbers for a stock motored machine. I think with your setup pump gas 9's would be easily doable. Any weight reduction? Still IRS? Have you thought about doing a 5.4 iron block instead of the 4.6? Intersting intake idea though, I dont think Ive ever seen it done but Im not huge into the turbo cobra scene either.Originally Posted by 2bscrewed
No problem, I can't drive the car right now, so i might as well talk about it! hahaI'm using my block bored .020 over, stock crank, Oliver billet rods, Coated JE pistons bringing the compression up to 9.2-1. New Livernois stage II heads with custom turbo grind comp cams. I'm gonna try a Procharger sheet metal intake designed to work with the stock lower. Hopefully the alternator will clear the intake. I'll find out when the top of the motor get together in a week or two. I'm hoping for at least 750whp on pump gas. I will also probably put a meth kit on the car next year to really turn up the boost and see what it will do. I also just got my tranny back from Liberty Gear. They faceplated it, and freshened it up. I'm hoping that will help the shifting out and allow me to stay in boost during the shifts. My tranny would not allow me to power shift in the past. that's why I'm granny shifting in my vid in my sig.
Quote:
I had a 3600# race weight with the blower and Bogarts. My street tire/wheel combo is about 50#'s heavier than the Bogarts. I have a built SRA. I haven't seen any turbo cars running the Procharger upper either, that's why I'm not sure how the Alternator is going to work out.Originally Posted by revracer
I don't really want to go the 5.4 route. I don't like the piston speeds it gets up to when you try to rev them with the long stroke of the 5.4. It would be fine for a race car, but it's not what I want in a street car.
