Z06 vs Cayman
Z06 will land you in trouble a lot faster.
However, I saw a cayman with some carbon ceramic GT3 brakes on it this past weekend. That in the new PDK Cayman would be a BLAST to drive where you can focus purely on hitting the points consistently.
Z06 hands down though
This is the fastest slip........bone stock on DR's. Say what you want, but you can't discount that this is a decent time for a 3,900 lbs four door lexus.....and you can't discount that high 11's with a tune are on the way from MHP where they are running 11.5's with their C63 with the same tune and a drop in filter
Yes, exact same wheels you had. 19/20 Astras with brushed centers.
[font=Verdana][color=#333333]12.3 at 115 at MIR on the 24 of Nov 2008 was right at 1500 below sea level if I recall right. Meaning negative DA for that day so using a time slip that day to compare trap speeds for your car is misleading. True numbers would have been high 113s or very low 114s if that.
