GT 500 KR X2 What color to buy ?
Old Jan 1, 2009 | 10:29 PM
  #31
richtor's Avatar
richtor is infamous around these parts
Originally Posted by SSNISTR
Let me repeat myself, Evan Smith is the best of the best. No other driver will be able to match those times. And nobody else has....
He ran a 12.8 in a bone stock '99 Z28, the best all the mags could muster was like a 13.5. I never saw anyone else run those times at the track either.
Also remember, Evan Smith powershifts. Most owners won't subject there car to that.
when did i say differently?
i am saying there is a big difference from the gt500 and the gt500kr? you are taking times from the gt500 and saying they are as fast as the kr. they are not the same car!
Old Jan 1, 2009 | 11:06 PM
  #32
8speed's Avatar
8speed is infamous around these parts
12.6 @ 114 mph is the quickest I've seen for a stock GT500 (I'm not counting the other two stock times because the Evan Smith pass doesn't have a picture of a slip and the other pass slip picture has Dodge Hemi above the slip).
http://www.dragtimes.com/results.php...=10&carmake=15
KR should get low 12's easily but I don't see how another 40 HP can knock of an entire second in the 1/4 mile
Old Jan 1, 2009 | 11:12 PM
  #33
997 rolls's Avatar
997 rolls is a glorious beacon of light997 rolls is a glorious beacon of light997 rolls is a glorious beacon of light997 rolls is a glorious beacon of light997 rolls is a glorious beacon of light997 rolls is a glorious beacon of light
Wider rear rims and tires that are more sticky.
Old Jan 2, 2009 | 12:31 AM
  #34
richtor's Avatar
http://www.dragtimes.com/results.php?resultpage=2&carmodel=1344&data1=100&o p1=>=&data2=1000&op2=<=&search2=et&days=10000000&s tock=&dyno=&resultsperpage=10&carmake=15
stock vert...
Originally Posted by MD03SVT
Just back back from the track for my 2nd outing with the Shelby & here are the results.Only changes were different launch & shift RPM's.
2.089/8.197/12.567/116.09 100% Stock on goodyears
1.777/7.775/12.102/116.964 with ET Streets
mods are in signature.
next time out with a tune.
stock coupe....
1st time out 18 may 2008 with 07 GT500 coupe 100% original at napierville dragway in montreal canada:
on stock goodyears 2.155/8.126/12.351/116.287
on slicks 1.790/7.669/11.861/117.025
not stock coupe(pulley, tune, suspension, gears, tires, roll bar, race gas)
Great air great traction = Great Times
Napierville dragway montreal canada oct 19th 2008
1.442 / 6.681 / 103.730 / 10.473 / 131.853 temp 46.4 57%H 30.49BP side/head wind 2.4mph 11.18am
1.457 / 6.702 / 104.183 / 10.498 / 131.200 temp 48.2 46%H 30.44BP
side/headwind 4.2mph 1.32pm
Mods 07 GT500 coupe race weight 3918lbs 8175 miles CFUXSEHGK
Stock clutch/transmission
Stock un-ported blower/TB
2.6 upper
08 GT500 stock lower
JLT CF intake
AR longtubes w/catted X-Pipe and MBRP axelback
Eibach lowering springs
Aluminum driveshaft w/loop
BMR U/L control arms & mount
4.10 gears w/detroit truetrac
Holeshot drag wheels 15x10 rear & 15x4 fronts
Hoosier 27x4.5x15 fronts & 28x10.5x15 rears
6pt NHRA legal roll-bar
Tuned by Jon Lund
40/60 mix of 94 octane pump gas and C16 race fuel
another driver with a stock run...
Originally Posted by FS MACH 1
I figured I should get my times up here finally
first last year
I ran a 12.33 STOCK on 10/28/07 link to it
http://www.svtperformance.com/forums...ighlight=12.33
the next week ran a 12.31 still STOCK didnt know it was that big
of a thing thought others had been faster !!!!!
thanks JEFF
Old Jan 2, 2009 | 06:51 AM
  #35
SINISTR's Avatar
SINISTR has a spectacular aura aboutSINISTR has a spectacular aura aboutSINISTR has a spectacular aura about
I think this is the first time I agree with you.
Old Jan 2, 2009 | 11:02 AM
  #36
richtor's Avatar
as you can see with the correct driver the gt500 is a 12.3 car. with different gearing, suspension, tires and more power the kr is .4 faster.
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
