Building a Blown LSX Block - Need Input
Old Apr 7, 2007 | 02:15 AM
Zippy's Avatar
Originally Posted by DERBOOST
distance from pin centerline to top of piston deck.
Thank you for answering my questions. I would really like to quite my job and work in a tuning shop to learn more about engine building. But I think my skills wouldn't command more than about $10.00 /hour! I'm glad this new forum was opened to discuss American Engines. It should prove to be very interesting to follow.
Regards, Mike
Old Apr 8, 2007 | 07:28 PM
dgussin1's Avatar
dgussin1 is infamous around these parts
I'd stay away from the LS7 block...it's pretty much a sleeved LS2 and will not stand up to much boost. I would go for a c5r or c6r block and ls7 heads...9.0:1 compression and 12-16psi of boost. Should be good for 1000rwhp +/-. Then again, why not throw a ford gt block and 4v heads in the car, you would need about 16psi to make 1000rwhp, but wouldn't have to worry about reliability. The mod motors hold boost much better than any lsx motor.
Old Apr 9, 2007 | 12:02 AM
01zincguy's Avatar
01zincguy is infamous around these parts
Honestly, any solidly built 408ci Iron block from any of the major LSx builders paired with a set of turbos will make the power you're looking for easily.
Old Apr 9, 2007 | 11:58 AM
Zippy's Avatar
What are your opinions of using a 3.3L Whipple v.s. a Twin Turbo set up?
Old Apr 9, 2007 | 12:54 PM
dgussin1's Avatar
twins all the way. No question about it. If you've got the money the turbos will make more power with less boost on pump gas.
Old Apr 9, 2007 | 03:39 PM
01zincguy's Avatar
Agreed. I really, really do not think you'll make anywhere near the power you want w/ a whipple. Go twins on an iron 408.
Old Apr 9, 2007 | 05:42 PM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
Turbo, forget the s/c for the power requested.
Old Apr 9, 2007 | 06:10 PM
Zippy's Avatar
Turbo it is then. Martin, the guy who will be building the engine, will be glad to hear this. Thanks.
Old Apr 9, 2007 | 06:53 PM
dgussin1's Avatar
I'd go for twin gt35r's with dual 3" downpipes and a big *** intercooler.
Old Apr 10, 2007 | 11:52 AM
01zincguy's Avatar
:werd: Twin 76mm with a 408 at 18psi will make 850+rwhp through an auto and a 12 bolt rear end.
Old Apr 10, 2007 | 06:34 PM
AaronK's Avatar
AaronK is a jewel in the roughAaronK is a jewel in the roughAaronK is a jewel in the roughAaronK is a jewel in the rough
I would speak to the guys at Wheel 2 Wheel. They produce some amazing results. They made 1250hp with a twin Rotrex supercharged Ls2. I wouldn't go with any other engine builder for an LSX with twin turbochargers/superchargers(other than NRE that is) Here is a link to their LSX twin supercharger package http://www.w2wpowertrain.com/pc-96-6...drive-kit.aspx
I should add that the twin supercharged LS2 drove coast to coast and was reliable, quiet and still turned in 9.25 sec 1/4 mile times at the dragstrip.
Old Apr 12, 2007 | 03:07 PM
Chris997's Avatar
Chris997 is infamous around these parts
Go with TT's. I have a 403 with 122ci Magnuson with a 3.2 pulley it is 6psi and 597 rwhp on pump gas.
Old Apr 16, 2007 | 10:43 PM
WyattTT's Avatar
WyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud of
Ive never heard of a 500" SB. The largest Ive seen is 454 Ford. After so many inches the heads will be limited, even the best aftermarket heads. A BB has so many more choices for heads, and are capable of so much more flow.
Stay small and turbo that thing.
Old Apr 17, 2007 | 06:21 PM
01zincguy's Avatar
GMPP's new LSx block 500+ci iron block. 2000+hp. That should do the trick with a 100+mm turbo
Old Apr 17, 2007 | 10:59 PM
dirtybird222's Avatar
dirtybird222 is infamous around these parts
There are a lot of guys building the LSX block to 511 inches and getting a lot of power out of it. If you are wanting to put a power adder on it go with the TT setup or a big single turbo setup.
What kind of vehicle are you putting this in?
And if you want a lot more help head over to LS1tech.com. They are very friendly over there, and they have a whole section on the forum dedicated to hybrid LSx vehicles. A lot of well educated individuals who know there pushrod motors!
